Challenger bumpers over the years... #2292567
04/23/17 08:19 AM
04/23/17 08:19 AM
the frozen wastes...
Pale_Roader Offline OP
Swears too much
Swears too much
I've got a 74 Challenger i'm trying to shave weight on. Its got a 70 front clip, but still has the 74 bumper.
I'VE BEEN TOLD... that the brackets are all the same, and only the bumpers got heavier. Over the years i've also gotten it in my head that there were subtle differences in the 70-72 'small' bumpers. The 70 being the lightest. I KNOW i've seen metal plate behind a 72 bumper, however small.
I dont care if the brackets look stock to Galen Govier, i just want it to look like a 70, and be as light as possible. Do i need 70 only stuff? Just the 70 bumper? What are the specific (even the subtle) differences?
I already have a 70 rear bumper and brackets... so no worries there. Also not interested in fiberglass.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2293340
04/24/17 06:27 PM
04/24/17 06:27 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
74 BARCKETS ARE not same as 1970
5549 post on old board
Re: Challenger bumpers over the years... [Re: 05dakota] #2293414
04/24/17 08:27 PM
04/24/17 08:27 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
the chrome bumper is the same shape/size but the hole location changed when the reinforcement bar was added
1970-'72 brackets are the same
1973-'74 brackets push the bumpers away from the car & used filler pieces to fill the gap
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2293673
04/25/17 06:13 AM
04/25/17 06:13 AM
Swears too much
Swears too much
Okay, i should clarify. I was told i could USE later brackets, by modifying them to mount the bumper closer (filing some slots, drilling holes or something). What i want to know is if the later brackets themselves are heavier than earlier ones. I'll hold out for earlier brackets if the later ones are 10lbs heavier. Weight reduction is a big theme here... especially up front.
What year was the bar added to the bumpers? Was a 71 heavier than a 70 bumper?
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2293779
04/25/17 12:11 PM
04/25/17 12:11 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
The bars were added in 73 when as mentioned they also pushed the bumpers further out and added the big ugly cushions, this was to meet the new 5mph crash standards. The bars are stand alone pieces that get sandwiched in between the bumper and the bracket, there's not much difference in the weight of any of the bumpers or the brackets themselves.
You could drill some holes in your front brackets, to relocate the bumper closer to the body like the earlier cars. More good info on that here-
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/4780596/site_id/1#import
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2293874
04/25/17 02:50 PM
04/25/17 02:50 PM
Outside
thedriver Offline
thedriver  Offline
Outside
Just redrill your 74 brackets to pull them back about an inch to get them flush, make sure that heavy bumper reinforcement bar is long gone, take the hole saw to the excess bracket material, boom, lightweight front brackets that mount the bumper flush
1973 challenger
Dana. 4 speed. Low deck.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2293917
04/25/17 03:41 PM
04/25/17 03:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I bought new Keystone bumpers for my 73 and had my original bumper guards re-chromed. The contour of the Keystone bumpers was WAY off. The bumper guards weren't even close to fitting. I don't know if it was an issue with the new bumpers or if the contour changed over the years. I'd be interested in seeing a 73 bumper guard installed on a 70 bumper to compare. I ended up getting my original bumpers re-chromed.
Correct, however 73 rear brackets are completely different from 74 rear brackets. 73 and 74 both use large/heavy reinforcement plates behind both front and rear bumpers. The rear reinforcement plates might also be different from 73 to 74 since the brackets are different. Not sure though.
You can re-drill the 73-74 FRONT brackets to move the bumpers in closer to the body. I'm not sure how easy it will be to remove the heavy reinforcement though. The bumper brackets mount directly to the reinforcement plate. Here is the only good picture I have that shows the bumper removed and what the large reinforcement plate looks like.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2294524
04/26/17 03:08 PM
04/26/17 03:08 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
This is a photo comparing front bumper brackets for a Challenger. The left is a '70 and the right is off of a '73. I believe the 70-72 and 73-74 brackets are interchangeable. Clearly the '70 bracket is shorter and the bumper mounts are different to accommodate for the larger bumperettes found on the '73-'74.
Regarding the weight, not sure how much difference there would be between the brackets. Perhaps a pound or two. I would think bare bumpers regardless of years would be nearly the same. The only other thing you may consider is to swiss-cheese the brackets to reduce some of the weight. You can eliminate the reinforcement plate located behind the bumper too.
Re: Challenger bumpers over the years... [Re: cruzin] #2294864
04/27/17 06:32 AM
04/27/17 06:32 AM
Swears too much
Swears too much
I wonder... and by the pics it would seem that if there was a small difference, it would be mainly in the extra length, and that the same thing chopped down to 70 size might not weigh much more at all.
Okay... so i'm up on brackets. If i cant find earlier ones i'll just hack mine. They're rough anyways.
On the bumpers... are we absolutely certain the 72 bumpers are exactly the same as 70-71? Not even a little plate behind them? I've heard conflicting reports over the years. I dont care about slots.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2294865
04/27/17 06:44 AM
04/27/17 06:44 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
The late 71-72 bumper is the same as 70-71 other than minor little cosmetic BS that you would never care about and that it has slots.
Re: Challenger bumpers over the years... [Re: Morty426] #2295466
04/28/17 04:28 AM
04/28/17 04:28 AM
Swears too much
Swears too much
Alrighty then. I guess i'm looking for a 70-72 front bumper, and maybe brackets too if they're cheap enough. I can live with that.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2295470
04/28/17 05:46 AM
04/28/17 05:46 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
There is not a lot of demand for 72 bumpers so that would be your cheapest route
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2295515
04/28/17 10:46 AM
04/28/17 10:46 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
you can use your '74 bumpers with 70-71 brackets you'll just have an extra hole on each side. Fill it with a bumper bolt. only catch is the chrome under the 5mph brackets may be in better shape then the rest of the bumper.
Gary
Re: Challenger bumpers over the years... [Re: Mr340] #2295929
04/29/17 04:03 AM
04/29/17 04:03 AM
Swears too much
Swears too much
Gary
No chance. Way too heavy. This build is all about light. Yours looks damn good though. I'd love to find a T/A hood for mine. Just sold one a few years ago too...
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2295952
04/29/17 09:17 AM
04/29/17 09:17 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Gary
Let me rephrase, that's a 73 bumper with all the extra reinforcements and bumperettes removed installed on 70 brackets, hence same weight as a 70-71 bumper with 2 extra bolt holes.
Re: Challenger bumpers over the years... [Re: Mr340] #2296372
04/30/17 03:21 AM
04/30/17 03:21 AM
Swears too much
Swears too much
Gary
I thought all that sh!te was welded in there? Is this easily done? I couldn't care less about bolt holes...
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2296401
04/30/17 09:39 AM
04/30/17 09:39 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
I thought all that sh!te was welded in there? Is this easily done? I couldn't care less about bolt holes... [/quote]
Check out Burdar's post, that pic shows the reinforcement with the bumper removed, it's bolted together, just soak the bolts with some wd-40 or rust penatrent first of course.
Re: Challenger bumpers over the years... [Re: Mr340] #2296779
04/30/17 09:37 PM
04/30/17 09:37 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Check out Burdar's post, that pic shows the reinforcement with the bumper removed, it's bolted together, just soak the bolts with some wd-40 or rust penatrent first of course. [/quote]
Correct, all of the reinforcements are bolted together. For the front you can reuse your bracket and bumper. Move the bracket back until the bumper sits where you want it, then re-drill the bracket to align with the bolt holes in the frame. Weight being a concern to you, you could then shorten the bracket a few inches to lose a few pounds.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2296780
04/30/17 09:38 PM
04/30/17 09:38 PM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
get jeff lingenfelters aluminum bumper brackets(lingenfeltersbrackets), he made some for my 72 cuda, they might weigh 3 lbs total, come with aluminum carriage bolts and i got aluminum 1/2" bolts for the frame.i went with a glass bumper as well.
Re: Challenger bumpers over the years... [Re: Pale_Roader] #2296973
05/01/17 06:07 AM
05/01/17 06:07 AM
Swears too much
Swears too much
Awesome! When it stops raining here i'll unbolt that albatross and see what i have to work with. The 74 bumper on my car is straight enough for my needs, and the brackets seem straight too. hackity hack hack...
As for buying aluminum... I'm sure they're beautiful... but for what you can see ov them to the casual eye, i'll save money and make my own when its time to. As long as the bumper sits where it needs to, i'm not terribly concerned what the brackets look like.
And i will never go fiberglass for bumpers. I do like to bat around the shopping carts every now and then... Plus, i hit no less than five animals in the 4 years or so i drove my Charger. I want at least something metal between the wildlife and my pretty new radiator...
