What Tranny fluid for a Stock late model big block 727 #229689
02/19/09 11:40 AM
02/19/09 11:40 AM
Cochise County Arizona
SPWC Offline OP
SPWC  Offline OP
Ended up dumping some fluid when I pulled the distick tube out on my 78 Cordoba.Is Dexron III or ATF III the stuff that I need to use to replenish what I lost?? Is this the same stuff?
Re: What Tranny fluid for a Stock late model big block [Re: SPWC] #229690
02/19/09 01:36 PM
02/19/09 01:36 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
either will be fine
