Re: Brett The Man Miller
[Re: B3422W5]
#2297121
05/01/17 01:46 PM
05/01/17 01:46 PM
Posts: 1,784 PA
W5DART66
PA
Almost 3 mph seems like a ton to go from 2200 feet to even 500-700 foot which would be considered excellent air in most places You correct to sea level. Not some arbitrary number. And the track I run at gets negative numbers. (We are spoiled with our good air here) 4th pass on new combination and went all most 156 with way wrong converter I am quite happy. With the power it makes it should run 160-161 in good air with car sorted out. Should be able to get some low 8.50s maybe some high 8.40s out of it. Look at time slip 5.55 to the 1/8 and still ran 8.70 its hunting mid track on. Thanks for the compliments guys. We will work on see what we can get out of it. 😀
[Re: fishy340]
#2297132
05/01/17 01:56 PM
05/01/17 01:56 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Adding 2.5mph to the 155.6 shows about 900hp.
That thing is pretty impressive for sure.
[Re: W5DART66]
#2297135
05/01/17 02:00 PM
05/01/17 02:00 PM
Posts: 11,720 Portage,michigan
B3422W5
Portage,michigan
Almost 3 mph seems like a ton to go from 2200 feet to even 500-700 foot which would be considered excellent air in most places You correct to sea level. Not some arbitrary number. And the track I run at gets negative numbers. (We are spoiled with our good air here) 4th pass on new combination and went all most 156 with way wrong converter I am quite happy. With the power it makes it should run 160-161 in good air with car sorted out. Should be able to get some low 8.50s maybe some high 8.40s out of it. Look at time slip 5.55 to the 1/8 and still ran 8.70 its hunting mid track on. Thanks for the compliments guys. We will work on see what we can get out of it. 😀 Cool. That's flying for sure. I bet it will 60 foot better. Lots of room there
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#2297211
05/01/17 03:50 PM
05/01/17 03:50 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
Not much at all b3422,I loosened my converter 500 rpm more and picked up 2 tenths and 3 mph with just that in my barracuda. 60' went from 1.41 to 1.35
[Re: fast68plymouth]
#2297416
05/01/17 09:45 PM
05/01/17 09:45 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Shows 845hp on the Moroso slide rule .. the Moroso slide is good for a well sorted out combination... I think from what was stated it's far from a sorted out deal
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: fishy340]
#2297492
05/01/17 11:56 PM
05/01/17 11:56 PM
B3422W5
Portage,michigan
Most important thing is it went 5.50s & 8.70 it's first day out with a converter that's been used like a mattress in a Bleep house.. Lol
[Re: fishy340]
#2297712
05/02/17 01:23 PM
05/02/17 01:23 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Congrats on the new best!
[Re: fishy340]
#2297730
05/02/17 01:48 PM
05/02/17 01:48 PM
Posts: 570 UK
rb446
UK
That sure is awesome!!!..... 883fwhp on the day under those conditions> 60 Foot E.T. : 1.21 1/8 Mile E.T. : 5.49 1/8 Mile Trap Speed : 123.85 1/4 Mile E.T. : 8.70 1/4 Mile Trap Speed : 154 at 0
Thats the exact scenario that would make me want to spend my money and make a come back over here and wipe some of those 540ci+ 2800lb door cars we have running mid to low 9's with a few doing high 8's off the track just like I did in the old days with my 340 v the 440's.....but thats a lot of money just to go brkt or index racing, which I'm not into these days.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2297930
05/02/17 09:29 PM
05/02/17 09:29 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Good job Brett.. I am impressed.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: B3422W5]
#2298046
05/03/17 01:01 AM
05/03/17 01:01 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Almost 3 mph seems like a ton to go from 2200 feet to even 500-700 foot which would be considered excellent air in most places You correct to sea level. Not some arbitrary number. And the track I run at gets negative numbers. (We are spoiled with our good air here) 4th pass on new combination and went all most 156 with way wrong converter I am quite happy. With the power it makes it should run 160-161 in good air with car sorted out. Should be able to get some low 8.50s maybe some high 8.40s out of it. Look at time slip 5.55 to the 1/8 and still ran 8.70 its hunting mid track on. Thanks for the compliments guys. We will work on see what we can get out of it. 😀 Cool. That's flying for sure. I bet it will 60 foot better. Lots of room there The car went 1.22 with old motor, that was 100hp less. The converter is way to tight for this combo, and it showed by only going 1.29 to the 60ft.
Brett Miller W9 cnc'd heads STR Chassis fabraction
