shock recommendation for 69 RR with ss springs #2294113
04/25/17 09:49 PM
04/25/17 09:49 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
I put in the NOS C body air shocks I had but one began leaking - I guessed it is a blown seal. To be honest i'm not that interested in figuring it out - can someone recommend shocks that will work well with the ss springs. I like a car that sits a little high anyway.
68 Satellite Wagon and a few other ones
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2294744
04/26/17 11:24 PM
04/26/17 11:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I'm running the Rancho 9000 XL II adjustable shocks on my Savoy and I love them. You can set them on #7-9 for racing then back them down to #1 or 2 to a smooth easy cruise down the highway up
Gus beer
64 Plymouth Savoy
Dana 60
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2294761
04/26/17 11:51 PM
04/26/17 11:51 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Thanks - checking them out
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2294903
04/27/17 10:11 AM
04/27/17 10:11 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i used these in my 69 RR with re-arched SS springs. i too like my car a little higher in the back. i had issues with tires rubbing when i go around corners and these helped. about 1/2 inch extra lift which will probably settle out but they are stiff enough to keep the roll under control.
http://www.manciniracing.com/kybgash.html
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2294928
04/27/17 11:02 AM
04/27/17 11:02 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
The Ranch 9000XL worked ok for me also down to the 10.50 range
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2295862
04/29/17 12:07 AM
04/29/17 12:07 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Rancho 9000's here too.
Nautilus Racing-
Re: shock recommendation for 69 RR with ss springs [Re: mro] #2295891
04/29/17 01:06 AM
04/29/17 01:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I just run the MP longer ext shocks which I believe are just C-body shocks. Ron
Re: shock recommendation for 69 RR with ss springs [Re: 383man] #2295947
04/29/17 08:58 AM
04/29/17 08:58 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
and i believe the KYB's i suggested are just truck shocks..
