shock recommendation for 69 RR with ss springs
#2294113
04/25/17 09:49 PM
04/25/17 09:49 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
I put in the NOS C body air shocks I had but one began leaking - I guessed it is a blown seal. To be honest i'm not that interested in figuring it out - can someone recommend shocks that will work well with the ss springs. I like a car that sits a little high anyway.
68 Satellite Wagon and a few other ones
Re: shock recommendation for 69 RR with ss springs
[Re: mro]
#2294744
04/26/17 11:24 PM
04/26/17 11:24 PM
Posts: 10,551 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm running the Rancho 9000 XL II adjustable shocks on my Savoy and I love them. You can set them on #7-9 for racing then back them down to #1 or 2 to a smooth easy cruise down the highway Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: mro]
#2294761
04/26/17 11:51 PM
04/26/17 11:51 PM
mro
Lynch Road
Thanks - checking them out
[Re: mro]
#2294903
04/27/17 10:11 AM
04/27/17 10:11 AM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
I put in the NOS C body air shocks I had but one began leaking - I guessed it is a blown seal. To be honest i'm not that interested in figuring it out - can someone recommend shocks that will work well with the ss springs. I like a car that sits a little high anyway. i used these in my 69 RR with re-arched SS springs. i too like my car a little higher in the back. i had issues with tires rubbing when i go around corners and these helped. about 1/2 inch extra lift which will probably settle out but they are stiff enough to keep the roll under control. http://www.manciniracing.com/kybgash.html
[Re: mro]
#2295891
04/29/17 01:06 AM
04/29/17 01:06 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I just run the MP longer ext shocks which I believe are just C-body shocks. Ron
[Re: 383man]
#2295947
04/29/17 08:58 AM
04/29/17 08:58 AM
mikemee1331
bethlehem pa
I just run the MP longer ext shocks which I believe are just C-body shocks. Ron and i believe the KYB's i suggested are just truck shocks..
