518 ultrabell column shift question #2295788
04/28/17 09:16 PM
04/28/17 09:16 PM
Laveen, Arizona
GTSDart340 Offline OP
Laveen, Arizona
I'm going to be putting a 518 behind a 440 in my 72 truck. My truck is column shift, and I know the ultrabell doesn't have provisions for the linkage. What's the best way to adapt the linkage? I don't really want to go to a floor shifter, but I will as a last resort. Thanks!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: 518 ultrabell column shift question [Re: GTSDart340] #2295792
04/28/17 09:29 PM
04/28/17 09:29 PM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
Make a bracket and screw it on the bellhousing. That's what I'm doing on my '77 440 truck
Re: 518 ultrabell column shift question [Re: GTSDart340] #2296423
04/30/17 11:12 AM
04/30/17 11:12 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Just did this two days ago. Used a long starter bolt and mounted the bracket I made to the backside of the starter.
