Tubular A-Arm Question- Now With Pics #229543
02/19/09 08:15 AM
02/19/09 08:15 AM
Indiana
Cuda_Mike Offline OP
Indiana
I'm installing a pair of Mancini's tubular a-arms, that I bought used on this site, on my B-body bracket car. I didn't get any instructions or hardware with them, and was wondering if I should use washers/spacers to equally space the rod ends in the center of the mounts? The original bushings were 1 7/8" where as the new ends are 1 3/8". Thanks for any input.
Re: Tubular A-Arm Question [Re: Cuda_Mike] #229544
02/19/09 10:38 AM
02/19/09 10:38 AM
San Diego
formula S Offline
formula S  Offline
San Diego
Reuse your old hardware, and you should have bin sent spacers with them. If you have rod ends you need spacers, if you have bushings washers should work
Re: Tubular A-Arm Question [Re: Cuda_Mike] #229545
02/19/09 01:50 PM
02/19/09 01:50 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm using mancini's A arms. big fat HT washer on each side sorted out the placement issues.
Re: Tubular A-Arm Question [Re: rebel] #229546
02/22/09 12:12 AM
02/22/09 12:12 AM
Indiana
Indiana
Drivers side installed. Are drum brake spindles the same on both driver and passenger side?
Re: Tubular A-Arm Question [Re: Cuda_Mike] #229547
02/22/09 02:42 PM
02/22/09 02:42 PM
Indiana
Indiana
