Building a 540 mega block #2294989
04/27/17 01:31 PM
04/27/17 01:31 PM
Upper Sandusky, Ohio
RoadSkinner Offline OP
Hey guys , I'm in the middle of building a 540 ...Mega block RB...I know some guys are gonna complain about my crank...But it's a 4.500 fuel crank....Not cracked...And I have diamond custom blower pistons....And wanna run 7.100 Manley pro I Beams rods...The crank is Mopar journal...So my question is how tight is it gonna b...And I think it will hit the cam.....What's the fix
Re: Building a 540 mega block [Re: RoadSkinner] #2294996
04/27/17 01:40 PM
04/27/17 01:40 PM
Did you sonic test that block first before boring it? If not do that now, a lot of the Mopar Mega blocks won't bore safely to 4.500 or larger, usually 4.410 or smaller is the normal bore size on them shruggy
As far as the steel rods on a 4.500 stroke crank with the Mopar rod journal size clearing the cam you should good, always check everything on any non stock motors twocents
If it does not clear the fix is using the BB Chevy rod journal sizes and rods with the same stroke shruggy scope
Re: Building a 540 mega block [Re: RoadSkinner] #2295002
04/27/17 01:47 PM
04/27/17 01:47 PM
gregsdart Online content
gregsdart  Online Content
I have run stock rods, 4.5 stroke, stock rb block, .500 lobe lift roller, had enough room. Hopefully the rods you have will also.
Re: Building a 540 mega block [Re: RoadSkinner] #2295009
04/27/17 01:58 PM
04/27/17 01:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I thought aluminum rods cleared and it wasn't until you went 4.750 stroke that the cam got in the way
Re: Building a 540 mega block [Re: RoadSkinner] #2295012
04/27/17 02:05 PM
04/27/17 02:05 PM
We didn't Sonic test the block....I think the bore 4.380...I was told the rods will hit the cam...And alot of block clearance ing.....And may have to get a custom cam ground....
Re: Building a 540 mega block [Re: RoadSkinner] #2295017
04/27/17 02:14 PM
04/27/17 02:14 PM
I'm getting ready to put a old KB top fuel crank with Mopar rod journal sizes on it into a new World cast iron hemi block with Manley steel SS Hemi rods, I'm sure I will have to grind on the block to make clearances on the oil pump boss and maybe the bottom of the cylinder skirts below the cam shruggy
I've done one other old top fuel 4.5 crank with steel rods in another, probably, a early Mega hemi block, and the cam was not even close up
Re: Building a 540 mega block [Re: RoadSkinner] #2295019
04/27/17 02:15 PM
04/27/17 02:15 PM
Cool...Good to know...Thanks guys
Re: Building a 540 mega block [Re: RoadSkinner] #2295026
04/27/17 02:25 PM
04/27/17 02:25 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
When I went to assemble my 572 years ago (4.5 bore, 4.5 stroke) with mopar journal size my crower billet rods hit the cam (bolt and nut style rod). I rebalanced with a set of K1 rods and all was well. I have since has my crank cut down to Chevy size
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Building a 540 mega block [Re: RoadSkinner] #2295046
04/27/17 03:07 PM
04/27/17 03:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
15+ years ago,Lou Vignogna put together my Mega block with a 4.5 stroke and 4.310 bore.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Building a 540 mega block [Re: FastmOp] #2295056
04/27/17 03:20 PM
04/27/17 03:20 PM
an8sec70cuda Offline
iagree I've always heard that 4.75" stroke w/ 2.2 journal steel rods will clear a std. cam height block, but aluminum will need a raised cam location.
Not sure where the end of the line is with the big mopar rod journals though.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Building a 540 mega block [Re: RoadSkinner] #2295057
04/27/17 03:24 PM
04/27/17 03:24 PM
Thats some grinding...What rod journal is on that crank...
Re: Building a 540 mega block [Re: RoadSkinner] #2295065
04/27/17 03:32 PM
04/27/17 03:32 PM
AndyF Offline
AndyF  Offline
You are going to buy 7.100 long rods with a Mopar rod journal on them? You are heading down a road where you have a big heavy rotating assembly with odd ball parts just because you started with the wrong crankshaft.
Re: Building a 540 mega block [Re: RoadSkinner] #2295069
04/27/17 03:42 PM
04/27/17 03:42 PM
Yes...But that's what I have ...im looking to make 1200 to 1500 HP ....I can't just use an eagle crank like everyone else
Re: Building a 540 mega block [Re: RoadSkinner] #2295124
04/27/17 04:38 PM
04/27/17 04:38 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Have you mocked it up yet. I run the chevy pin size 4.5 crank in two shortblocks. I clearance the stock late 70s block in the spots Hemi-it's posted and at the bottom of a few bores. I run a pro mod type aluminum rod by GRP in both. I also run big lift.
Re: Building a 540 mega block [Re: RoadSkinner] #2295130
04/27/17 04:48 PM
04/27/17 04:48 PM
No I haven't got the rods yet....They are back ordered...Then I'll mock it up...I was told to custom grind a cam with a smaller base circle to clear the rod....Does that sound right
Re: Building a 540 mega block [Re: RoadSkinner] #2295157
04/27/17 05:41 PM
04/27/17 05:41 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
How much lift? I have .800 on my cast iron Indy heads on my stock block 540
Re: Building a 540 mega block [Re: RoadSkinner] #2295165
04/27/17 06:13 PM
04/27/17 06:13 PM
Small cam....685 lift roller
Re: Building a 540 mega block [Re: RoadSkinner] #2295168
04/27/17 06:18 PM
04/27/17 06:18 PM
That's the cam I have now in my old motor....May go with a different cam in the this mega block motor...Well see but nothing too wild I drive this on the street alot...
Re: Building a 540 mega block [Re: RoadSkinner] #2295182
04/27/17 07:02 PM
04/27/17 07:02 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Just make sure you check it but I think you will be ok. Sometimes a redegree of the cam will gain you room.
So what's the plan to make 1200hp? Nitrous?
Re: Building a 540 mega block [Re: RoadSkinner] #2295214
04/27/17 07:57 PM
04/27/17 07:57 PM
I have the car running now with my stock block 528...Its got an F2 Procharger on it ....Blow thru dominator....It will make the power I need...I just don't wanna break the block....So that's why it's getting the new short block
