Re: 400/512 Questions
[Re: 440mopar]
#2294533
04/26/17 03:29 PM
04/26/17 03:29 PM
Posts: 4,672 Wichita
GY3
Wichita
I have a few questions about building a 400/512. First, are Edelbrock Performer RPM heads a good/big enough head for a 512? Second, will 1 3/4" tube headers hooked to 2 1/2" diameter exhaust system be large enough for a 512? And third, is there anyone else other than 440 Source and Muscle Motors that sells 400/512 rotating assemblies? That head works, but it works better after someone does a CNC port on them. ...or just buy Trickflows that are already ported. If it is a street car that exhaust will work fine. I didn't buy a kit but rather bought a Molnar crank, Molnar rods and Mahle pistons. It was great quality parts for very similar cost of a "kit". There is a handy chart AndyF posted in the tech section that helps with rod length and piston selection. http://www.moparts.org/Tech/Archive/bb/BBM_Stroker_Pistons.html
[Re: 440mopar]
#2294599
04/26/17 06:12 PM
04/26/17 06:12 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
What are you starting with, and what do you want the final engine combination to do?
A standard port head will have peak torque at a lower RPM than a Max Wedge sized port head, so it partly depends on where you want the torque curve to be and total amount of power. If your just building a street engine than the standard port heads are fine. For a race engine, you would want the larger port size heads, but being a low deck really limits intake choices when using Max Wedge port size heads. I think only Indy sells cast intakes for the max wedge low deck combination?
Standard port heads allow a wider selection of intake manifolds. For the street, the RPM Air-Gap is popular.
I have the TTI 1-7/8" headers on the mild 505" 440 with Stealth heads in the convertible with the TTI 2-1/2" "X" crossover exhaust. In that vehicle I wanted good header clearance and quiet sound. If your building a race or street/strip setup like the 500" 400 MW victor head engine in my Charger, then there is some performance to be gained with 2" headers and 3" exhaust.
I am tying to save up to build a 512 (really 505" 440) for my Jensen Interceptor using the Trick flow heads, but medical issues are killing my bank account. This setup I plan to build my own headers with 1-7/8" first step, and either build step headers or Tri-Y headers for the car. Either way, the tube diameters will grow larger from the initial 1-7/8".
[Re: 440mopar]
#2294727
04/26/17 10:57 PM
04/26/17 10:57 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
For your deal I would buy the two inch headers with 3 or 3.5 inch collectors and put a 3 inch exhaust system on the car to start with now instead of later You've already made the motor bigger for more power, correct Do the same on the exhaust now instead of later, it always costs more later My old 440 powered Dart picked up .8 ET and 8.+ MPH in the 1/4 mile by removing the two and half inch exhaust system from the car It had the old Thrust 2.5 inch Turbo muffs hooked up to the Hooker 1 7/8 Hooker fender well headers with 3.5 inch collectors back about 18 inches with 2.5 inch pipes to the Turbo mufffs and then around 18 inches more of 2.5 inch pipes out to the side exhaust Very restrictive
[Re: 440mopar]
#2294940
04/27/17 11:29 AM
04/27/17 11:29 AM
Posts: 35 Canada
Criterion
Canada
If it's a real street car, I would stay with 2.5" mandrel bent pipes. Yeah, you would be giving up horsepower and not an insignificant sum of it. With a 3" exhaust, however, you are going to have to really consider packaging constraints and noise. A 3" exhaust, all things being equal, will be significantly louder.
My '65 Fury has 1 7/8's tti headers, a full 2.5" tti exhaust out the back and the longest body of muffler that Borla makes. When I ran that exhaust on a mild 383 it was nice and mellow. After I moved to my 512 the car is now noticeably louder, with an emphasis on low frequencies. If I had 3" pipes right now I would definitely be looking for ways to quell the decibels. Additionally, there is no way in hell I'd run a larger header on my car. The current pipes are big enough for an afternoon of head scratching and vocabulary building as it is.
And for reference I use a 512 with a Molnar crank and rods, Diamond pistons (stock PN), and Trick Flow heads. It makes around 10.3:1 and uses a Straub solid roller cam.
[Re: 440mopar]
#2295300
04/27/17 10:15 PM
04/27/17 10:15 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
For a street car the heads will be fine. My 4000lb wagon has been 11.0's with a small mech cam from Comp. The heads are untouched RPM's except for making sure the valves seat properly and the guides were not too tight. I shift at 5500 and cross the stripe at 6100(my convertor is a little looser than planned). I would go w/a 2" header. I run TTI stepped 2-2 1/8". I will be adding a little more cam and head work later so I will grow into them. I will say if the Trick Flows had been available when I built this I would have gone that direction.
Ohio Crank, scat, Molnar are other sources. I do have a 440 source kit. It was spot on per my machinist.
Ok
