Re: Which RB valley pan for milled heads and zero decked block?
[Re: Adam71Charger]
#2294953
04/27/17 11:59 AM
04/27/17 11:59 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
I have used the normal 1215 valley pan (like above) on a 440 w/ a pair of 915 heads that had been milled a lot (about .080"). It will crush down were it needs to be if that makes sense. Had to cut clearance notches on the intake so the end rails of the block didn't hold it up off the intake face of the heads.
It sucks your block has been milled so much already since you're going to be testing a few different manifolds. Having to mill the manifolds to fit the block/head combo will really hurt the resale once you find which one you like the best.
[Re: an8sec70cuda]
#2295266
04/27/17 09:18 PM
04/27/17 09:18 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
As standard course for the past 40 years I have at least 0.045" to 0.060" milled from all cylinder head intake surfaces. It eliminates all alignment and fitment issues
[Re: Adam71Charger]
#2295622
04/28/17 02:16 PM
04/28/17 02:16 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I'd definitely mill the heads instead of the intakes. It opens up far more opportunities in the future.
[Re: Adam71Charger]
#2295683
04/28/17 04:41 PM
04/28/17 04:41 PM
an8sec70cuda
I wouldn't necessarily want to mill the heads to compensate for the block being decked. Then you've got an even more expensive set of parts married to one block. I'd rather cut the intake in that case.
Let me clarify...If all you do is deck the heads and then cut the intake face...they're good to go on anything. But w/ the combination of heavily decked heads AND the block too...even if the top of the block has been cut to compensate, it will need to be mocked up to see. If there is still a mismatch, I would not cut the heads more to make it up...rather cut the intake.
[Re: an8sec70cuda]
#2295738
04/28/17 07:20 PM
04/28/17 07:20 PM
BSB67
Prospect, PA
Let me clarify. I don't do it because of heavy milling of anything. If you mill nothing, us two 0.030" gaskets per side. If you zero deck to a typical 2.060" piston and clean up the heads, use a total of 0.045 to 0.030". No matter what you put the heads on, it will probably work. It just gives so much flexibility, and the intake seals every time too. Here is the other beauty, I use light coating of grease on the gaskets. I'll test three intake manifolds in an evening on the dyno, or a day at the track.
[Re: Adam71Charger]
#2296444
04/30/17 11:55 AM
04/30/17 11:55 AM
Posts: 74,976 U.S.S.A.
JohnRR
U.S.S.A.
If the block was zero decked for the 6pk piston it's only had maybe .025 taken off, that's not too much. As long as the heads were milled on the intake face to match was was taken off the heads he should be pretty close. You aren't going to be able to use the .030 gaskets that come with that valley pan and the fel pro gaskets suck anyway , I don't know what material they are made of but they seem to wick oil?? Get superformance gaskets , I think you can get them as thin as .010 , but you'll have to egg the intake bolt holes with all those gaskets and the block deck possibly ???
If the china walls weren't cut when the block was decked then you might have an issue trying to used a solid valley plate, especially one that would go under the edge of the head.
