727 front drum billet steel vs billet aluminum piston #2294302
04/26/17 02:22 AM
04/26/17 02:22 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Talked to John Cope today about billet steel front drum. The billet steel drum is available with a billet steel piston from John, but with billet aluminum from other vendors. Pros and cons of the piston material? Does it really matter?
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294344
04/26/17 07:26 AM
04/26/17 07:26 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
I've run both. I like the aluminum drum. The billet steel is very heavy. I think the clutch and band wear is better with the aluminum. For sure my car was .10 quicker in the 1/8 back to back.
Doug
Re: 727 front drum billet steel vs billet aluminum piston [Re: dvw] #2294398
04/26/17 11:12 AM
04/26/17 11:12 AM
Mt Morris Michigan
Mt Morris Michigan
Which aluminum drum did you use, full metal jacket or all aluminum. Again, curious to the piston material, billet steel billet aluminum. Does it make any difference?
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294414
04/26/17 11:25 AM
04/26/17 11:25 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My steel drum from CRT came with an aluminum piston.
Re: 727 front drum billet steel vs billet aluminum piston [Re: justinp61] #2294416
04/26/17 11:28 AM
04/26/17 11:28 AM
an8sec70cuda Offline
iagree Pretty sure the billet steel A&A drum I bought from CRT came w/ an aluminum piston.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294430
04/26/17 12:07 PM
04/26/17 12:07 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
I have run both billet aluminum and billet steel drum. The car lost nothing! Ran exactly the same #'s. Not having to change trans fluid every 25 passes like they say you should with the aluminum drum is a bonus. As far as the piston material goes? We have an aluminum piston but steel should be fine also. I wouldn't give the piston material a second thought.
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294432
04/26/17 12:07 PM
04/26/17 12:07 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Both drums came from A&A. Last inspection all clutches and bands looked new. It had 150 passes with no fluid change.
Doug
Re: 727 front drum billet steel vs billet aluminum piston [Re: justinp61] #2294448
04/26/17 12:30 PM
04/26/17 12:30 PM
Mt Morris Michigan
Mt Morris Michigan
My mistake. went back to copes site and it does not list piston material, just says billet. He does offer an ultimate billet steel as well as a billet steel drum. More money for the ultimate, just curious to whats included with it.
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294502
04/26/17 02:21 PM
04/26/17 02:21 PM
I would look for and buy the aluminum drum with the steel liner for the band up twocents
I should buy several of them now before I need them, huh whistling realcrazy
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294513
04/26/17 02:52 PM
04/26/17 02:52 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
My vote is for the aluminum drum with the steel sleeve, and aluminum piston, light weight, is easy on the band. I never tried a back to back test on 1/4 mile times. But since the drum has to be stopped by the band for 2nd gear, the lighter the drum the less stress on the band. Plus it is better material so it will not explode like the stock drum at high RPM'S
Re: 727 front drum billet steel vs billet aluminum piston [Re: jwb123] #2294551
04/26/17 04:14 PM
04/26/17 04:14 PM
Mt Morris Michigan
Mt Morris Michigan
I talked to John Cope yesterday about that drum. He said he had one in the shop when they first came out. wasn't impressed with it and thought it looked cheesy. I haven't totally gave up on the full metal jacket just yet. Too bad their isn't someone on here that can give us first hand info on it. ya or nay.
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294663
04/26/17 08:31 PM
04/26/17 08:31 PM
organ
maximum entropy Offline
organ
i have the billet steel drum in my scamp, and i recommend it highly. i got mine from cope.
Re: 727 front drum billet steel vs billet aluminum piston [Re: jwb123] #2294682
04/26/17 09:09 PM
04/26/17 09:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you knew the facts about a stock drum blowing up you
wouldnt say that last line of your statement.. a stock
drum is fine IF you dont trash your over running clutch..
if you trash the over running clutch you then spin the
drun 2.2 times the engine rpm.. DONT pedal the engine while
your still in low gear( if you spin.. SHIFT).. if you
trashed the over running clutch the drum can take ABOUT
6600 rpm before it reaches the point that centrifugal
force will let it blow.. I'm still running a stock drum
and have been since I started racing(a number of years now)..
if you dont do stupid stuff you wont have a problem.. but
of course a lot of people will say it will blow.. BS..
dont do stupid stuff... OK now all of you can say I'm wrong..
but I've still never blew one up.. and I turn at least 8200 rpm
on every shift.. also this is in the same boat that if you
put a bolt in sprag, your fine.. more BS.. a bolt in sprag
is for one that spun in the housing
wave
Re: 727 front drum billet steel vs billet aluminum piston [Re: justinp61] #2294717
04/26/17 10:44 PM
04/26/17 10:44 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
so did mine
Re: 727 front drum billet steel vs billet aluminum piston [Re: MR_P_BODY] #2294722
04/26/17 10:50 PM
04/26/17 10:50 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
wave
I agree with you Mike. the only reason I put a steel drum in mine was the old stocker was junk so I needed one anyway and verytrue on the bolt in sprag too.
Re: 727 front drum billet steel vs billet aluminum piston [Re: mopar dave] #2294759
04/26/17 11:48 PM
04/26/17 11:48 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
break a rear gear on launch, shock the driveline and roll the sprag.... what happened that was so stupid in this scenario??
Re: 727 front drum billet steel vs billet aluminum piston [Re: MR_P_BODY] #2294760
04/26/17 11:50 PM
04/26/17 11:50 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I have been racing since 1974, all but one car mopars. I never have broken a roller clutch, have never blown up a drum either. As you say proper burn out technique will keep the roller clutch in good shape. A broken drive shaft at the wrong time will destroy a roller clutch and no driving technique will stop that from happening. But two of my buddies in one year with just as much experience as me, did blow up their transmissions and it was not pretty, both were hurt, but fortunately not seriously. Both had carbon fiber shields and both got pieces in the car. The drum in a 727 is a bomb waiting to go off, the cost of a good drum is cheap insurance for your car and yourself. I know exactly the science why the drum can and does blow up and have seen the results several times. One night in a hospital will pay for several drums, the cost of a drum is cheaper than a whole transmission case in pieces on the track. Seems common sense to my to buy a good drum. I just figured my luck was no different than my friends.
Re: 727 front drum billet steel vs billet aluminum piston [Re: jwb123] #2294773
04/27/17 12:08 AM
04/27/17 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Then buy one if it makes you feel better
wave
Re: 727 front drum billet steel vs billet aluminum piston [Re: MR_P_BODY] #2294798
04/27/17 01:09 AM
04/27/17 01:09 AM
Mt Morris Michigan
Mt Morris Michigan
I'm gonna buy the aluminum full metal jacket or the steel billet just for piece of mind. Starting with a fresh build so kinda a no brainer anyway. Just need to make up my mind and get the full order in by friday, my trans builder is waiting.
Re: 727 front drum billet steel vs billet aluminum piston [Re: MR_P_BODY] #2294872
04/27/17 08:07 AM
04/27/17 08:07 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
but I've still never blew one up.. and I used to turn at least 8200 rpm
wave
Fixed it for ya. wave
