Need Some Head Milling Advice-Stock 71 383 HP Motor
#229445
02/19/09 12:33 AM
02/19/09 12:33 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
I want to bump up the compression on my 383,built in late 70'(if it matters).I'll assume the worst as far as the pistons being down in the hole,with 346 heads. Heads have not been off yet,I just need a basic hypothetical here.I'm going to run a copper gasket,and want to mill the heads.Any suggestions to how far I can safely mill them,thoughts of that nature. Regardless how much compression I do have now,I want to come up at a minimum of 3/4 of a point. Also any cost effective tips to keep the geometry of the valvetrain correct. The only money I plan on spending on this motor is for the milling,gasket set and a timing chain after I degree the stock cam. Thanks for any help guys.Project is coming along nicely thanks to this site and some of the help from guys on here, !
'71 383HP FJ6 Charger SE
Re: Need Some Head Milling Advice-Stock 71 383 HP Motor
[Re: 74fldart]
#229447
02/19/09 01:05 AM
02/19/09 01:05 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Sounds good so far,..anyone else. I DID mean steel gaskets,sorry. Thanks dude
[Re: 71 FJ6 Charger]
#229448
02/19/09 01:21 AM
02/19/09 01:21 AM
Posts: 1,647 IL
71383beep
IL
Don't forget about the intake face too.
You'll need to mill that too to keep your intake.
As fas as how far to mill it is difficult to say without knowing how far down the pistons actually are. If you really are that serious in milling the block or heads you're gonna have to either take it out of the car or at least pull the heads so I would just take a weekend day and pull her out of there and measure it all up. It;s gonna have to come almost completely apart anyways...especially if you mill the block.
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: 71383beep]
#229449
02/19/09 01:52 AM
02/19/09 01:52 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Its out of the car,right year but not original motor. But like I said,I'm doin' no more than I mentioned before. To solve the intake problem,I'll just have the intake side of the head milled also. I'm gonna pull a head off tomorrow and see how deep. I'll post it up.
[Re: 71383beep]
#229450
02/19/09 01:57 AM
02/19/09 01:57 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I can see the lure of compression, but reality is, that most pro engine builders agree a gain of 3 to 4% is seen with 1.0 point comp gain.(IIRC) That said, a stock hp 383 probably made 300hp in real life.(not the rating, a close to true value) So when your done, you'll be up to 312. Lots of work for little gain. I think a well selected cam, with some advance ground into it, and a dialed in ignition system with the right amount of initial advance, and a good curve would yield much better results. More like 50 hp Cost of a cam and lifters, and a timing cover gasket set, and half the labour of the compression gain plan
[Re: dave571]
#229451
02/19/09 03:34 AM
02/19/09 03:34 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
Well I was bored so I took one off.Suprised to see how clean it is. But am I reading this right?.........I'm getting .063 down.? That cant be,can it? I measured it 3 times. Pistons are flat tops.Very clean.... Anyone?
#229453
02/19/09 10:32 AM
02/19/09 10:32 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
if you don't go crazy milling the haeds and don't do something stupid like using rocker shaft shims to make up for aggressive head and/or block milling then ABSOLUTELY NOTHING is going to change your valvetrain geometry .
You want to check your current lifter preload , if it's on the low side of acceptable then you can figure out how much you can mill the heads and not cause any issues , worst case is you have to get a new set of pushrods .
[Re: JohnRR]
#229454
02/19/09 11:28 AM
02/19/09 11:28 AM
Posts: 403 NE Ohio
71 FJ6 Charger
NE Ohio
How much pre-load do I need,and if I were to get a set of adjustable pushrods,would I not just adjust them the same amount that I took off of the head?
#229457
02/19/09 12:58 PM
02/19/09 12:58 PM
JohnRR
U.S.S.A.
The number I seen thrown around is .060 of preload , you need to make sure the pushrods are not bottoming out in the lifter.
As far as adjustable pushrods , a crutch for the correct part .
[Re: JohnRR]
#229458
02/19/09 01:30 PM
02/19/09 01:30 PM
Posts: 1,908 Nebraska
4406bbl
Nebraska
No you would adjust them the same amount you took off the head times the rocker ratio so more like .090. I have taken .090 off of 346 heads and never had a problem,but you will need to mill the intake side also, about.090if you mill the heads .060,your machine shop should have a gauge to measure that,if not find a new one. You need .020 lifter preload .060 is too much and is a big reason some engines are dogs. There is nothing wrong with adjustable pushrods for your application,they will work.
