Re: 727 front drum billet steel vs billet aluminum piston
[Re: justinp61]
#2294416
04/26/17 11:28 AM
04/26/17 11:28 AM
Posts: 13,365 Marion, South Carolina [><]
an8sec70cuda
My steel drum from CRT came with an aluminum piston. Pretty sure the billet steel A&A drum I bought from CRT came w/ an aluminum piston.
[Re: mopar dave]
#2294502
04/26/17 02:21 PM
04/26/17 02:21 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
[Re: mopar dave]
#2294663
04/26/17 08:31 PM
04/26/17 08:31 PM
Posts: 5,080 organ
maximum entropy
organ
i have the billet steel drum in my scamp, and i recommend it highly. i got mine from cope.
[Re: jwb123]
#2294682
04/26/17 09:09 PM
04/26/17 09:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My vote is for the aluminum drum with the steel sleeve, and aluminum piston, light weight, is easy on the band. I never tried a back to back test on 1/4 mile times. But since the drum has to be stopped by the band for 2nd gear, the lighter the drum the less stress on the band. Plus it is better material so it will not explode like the stock drum at high RPM'S If you knew the facts about a stock drum blowing up you wouldnt say that last line of your statement.. a stock drum is fine IF you dont trash your over running clutch.. if you trash the over running clutch you then spin the drun 2.2 times the engine rpm.. DONT pedal the engine while your still in low gear( if you spin.. SHIFT).. if you trashed the over running clutch the drum can take ABOUT 6600 rpm before it reaches the point that centrifugal force will let it blow.. I'm still running a stock drum and have been since I started racing(a number of years now).. if you dont do stupid stuff you wont have a problem.. but of course a lot of people will say it will blow.. BS.. dont do stupid stuff... OK now all of you can say I'm wrong.. but I've still never blew one up.. and I turn at least 8200 rpm on every shift.. also this is in the same boat that if you put a bolt in sprag, your fine.. more BS.. a bolt in sprag is for one that spun in the housing
[Re: justinp61]
#2294717
04/26/17 10:44 PM
04/26/17 10:44 PM
dartman366
Mt. Vernon, Ohio
My steel drum from CRT came with an aluminum piston. so did mine
[Re: MR_P_BODY]
#2294722
04/26/17 10:50 PM
04/26/17 10:50 PM
dartman366
Mt. Vernon, Ohio
My vote is for the aluminum drum with the steel sleeve, and aluminum piston, light weight, is easy on the band. I never tried a back to back test on 1/4 mile times. But since the drum has to be stopped by the band for 2nd gear, the lighter the drum the less stress on the band. Plus it is better material so it will not explode like the stock drum at high RPM'S If you knew the facts about a stock drum blowing up you wouldnt say that last line of your statement.. a stock drum is fine IF you dont trash your over running clutch.. if you trash the over running clutch you then spin the drun 2.2 times the engine rpm.. DONT pedal the engine while your still in low gear( if you spin.. SHIFT).. if you trashed the over running clutch the drum can take ABOUT 6600 rpm before it reaches the point that centrifugal force will let it blow.. I'm still running a stock drum and have been since I started racing(a number of years now).. if you dont do stupid stuff you wont have a problem.. but of course a lot of people will say it will blow.. BS.. dont do stupid stuff... OK now all of you can say I'm wrong.. but I've still never blew one up.. and I turn at least 8200 rpm on every shift.. also this is in the same boat that if you put a bolt in sprag, your fine.. more BS.. a bolt in sprag is for one that spun in the housing I agree with you Mike. the only reason I put a steel drum in mine was the old stocker was junk so I needed one anyway and verytrue on the bolt in sprag too.
[Re: MR_P_BODY]
#2294872
04/27/17 08:07 AM
04/27/17 08:07 AM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
If you knew the facts about a stock drum blowing up you wouldnt say that last line of your statement.. a stock drum is fine IF you dont trash your over running clutch.. if you trash the over running clutch you then spin the drun 2.2 times the engine rpm.. DONT pedal the engine while your still in low gear( if you spin.. SHIFT).. if you trashed the over running clutch the drum can take ABOUT 6600 rpm before it reaches the point that centrifugal force will let it blow.. I'm still running a stock drum and have been since I started racing(a number of years now).. if you dont do stupid stuff you wont have a problem.. but of course a lot of people will say it will blow.. BS.. dont do stupid stuff... OK now all of you can say I'm wrong.. but I've still never blew one up.. and I used to turn at least 8200 rpm on every shift.. also this is in the same boat that if you put a bolt in sprag, your fine.. more BS.. a bolt in sprag is for one that spun in the housing Fixed it for ya.
