Magnum heads Educate me #2293893
04/25/17 03:16 PM
04/25/17 03:16 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Hi all
I need some help.
Are all Magnum heads the same basic casting?
Do 318 and 360 heads have the same casting?
Why are R/T heads better?
Thanks for your time..
Re: Magnum heads Educate me [Re: SSDart] #2293966
04/25/17 04:59 PM
04/25/17 04:59 PM
dogdays Offline
dogdays  Offline
All Magnum heads are functionally the same. The 5.2 Mags are US sourced, the 5.9 heads are Mexico, although there has never been a preference one to the other.
There is some confusion about the name R/T. At the same time that Mopar was selling a model with the R/T name, they were selling Magnum R/T heads. The two are not the same. The heads in the R/T trucks were exactly the same as any other Mag head. The MP Magnum R/T heads were better flowing and if MP ran true to form back then, they were pretty expensive. I don't think you can get them new any more and cost is probably the reason.
The Mag heads had the best combustion chamber of any OEM Mopar up until that time. Dual squish pads really can wake up the air/fuel if the engine is built for squish. The intake side flowed adequately and the exhaust was relatively high flowing. Mag heads do not usually need a dual pattern cam.
IF you are looking for better heads the first that come to mind are Enginequest. These cast iron heads aren't cheap, but they are capable of making more power, just out of the box. Then there are the Edelbrock Mag heads and now the Sidewinder smallblock may have provisions for Mag stuff, call Mr. Marsh (Sasquatch). Speedmaster (ProComp) has a cast iron head that is Mag configuration. There may be others but that's all that come to mind.
R.
Re: Magnum heads Educate me [Re: dogdays] #2293969
04/25/17 05:05 PM
04/25/17 05:05 PM
Moparts
SSDart Offline OP
SSDart  Offline OP
Moparts
Thanks for the quick reply. So a 5.2 head will have the same ports as a 5.9?
Re: Magnum heads Educate me [Re: SSDart] #2293971
04/25/17 05:06 PM
04/25/17 05:06 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
5.2 and 5.9 heads, same casting.
Although there was a Dakota R/T vehicle it did not come with
Special heads.
Magnum R/T heads are an aftermarket Mopar Performance
Product, which were brought to market to replace stock heads for crate
Engines when the supply of new Chrysler (oe) heads ran out. They were never sold
On any production vehicle.
The exhaust ports are noticeably nicer than oe heads and they were available with
Both stock and 2.02/1.6 valve sizes. Bare and complete. As they waned in popularity Mopar replaced Them with eq heads but the ship had mostly sailed by then, and folks were buying eq products off eBay for the most part.
Rich H.
Esse Quam Videri
Re: Magnum heads Educate me [Re: SSDart] #2293975
04/25/17 05:07 PM
04/25/17 05:07 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Yes, stock heads-same ports.
Rich H.
Esse Quam Videri
