Correct Hardware? #2293919
04/25/17 03:42 PM
04/25/17 03:42 PM
68gtx Offline OP
68gtx  Offline OP
68 GTX rear trim panel is done. Now I need the correct Pal Nuts speed nuts what ever you may call them. I ordered a set from E-Bay and they do not fit the studs. Who has the correct hardware for this GTX? Thanks Larry J
Re: Correct Hardware? [Re: 68gtx] #2294020
04/25/17 06:27 PM
04/25/17 06:27 PM
68gtx Offline OP
68gtx  Offline OP
Anyone?
Re: Correct Hardware? [Re: 68gtx] #2294023
04/25/17 06:32 PM
04/25/17 06:32 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Try this link I would call them
CLICK HERE FOR LINK
Re: Correct Hardware? [Re: CSK] #2294193
04/25/17 11:48 PM
04/25/17 11:48 PM
68gtx Offline OP
68gtx  Offline OP
Thanks I will try them. I looked on their web site and did not see them. Thanks Larry j
