Some teaser pics of my rear disc swap #2292592
04/23/17 10:23 AM
04/23/17 10:23 AM
Guitar Jones Offline OP
This will be going on my 92 D250 with a Dana 70. I got the brackets from Great Lake Off Road, the calipers, rotors and pads are all for the front of a 86 Chevy K20 which is a 3/4 ton 4X4.
I'm still waiting on the brake hose mounting tabs. I have a kit coming from Summit by Classic Performance that uses a band clamp to hold the tab. That will just be temporary until I can get the tabs welded on the housing.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2292731
04/23/17 02:42 PM
04/23/17 02:42 PM
Alberta
440_Offroader Offline
Alberta
Cool deal. I'll be watching as I want to do the same conversion on one of my trucks. I like the fact that you're just using factory Chevy brake parts... Easier to get parts for. Are you just putting in an adjustable valve for the rear brakes or using a different proportioning valve?
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2292739
04/23/17 02:52 PM
04/23/17 02:52 PM
The truck has RWAL already so I probably won't need to change anything there. We'll see how it works. It does lose the parking brake though. I really never use it anyway but I may do something else for that, haven't decided yet.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2292760
04/23/17 03:39 PM
04/23/17 03:39 PM
Alberta
Alberta
For a parking brake, I'm going to run a disk brake off my tranfer case as I have a flanged yoke there anyways. Just a option for you.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2292855
04/23/17 06:40 PM
04/23/17 06:40 PM
Mine is 2WD so not an option for me.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2292951
04/23/17 10:29 PM
04/23/17 10:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
there is a cadillac rear caliper that bolts in the same place----it is a big time junkyard or swap meet score---they are now being made again...
Re: Some teaser pics of my rear disc swap [Re: savoy64] #2293119
04/24/17 10:07 AM
04/24/17 10:07 AM
It was a two or three year only Eldorado caliper. You can find remans but not with the levers. It's the levers that are hard to find. If you know a source please post it up. I've been searching for quite awhile now and can't really find anything that is under a few hundred dollars each.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2293647
04/25/17 02:37 AM
04/25/17 02:37 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Don't take this wrong....BUT are the stock drum brakes that bad? I thought the truck manufacturers went to rear discs to save money, not for better performance. Big rigs still use drum brakes on the trailers so they aren't really obsolete.
What was the intended gain?
Re: Some teaser pics of my rear disc swap [Re: Kern Dog] #2293708
04/25/17 09:28 AM
04/25/17 09:28 AM
Disc brakes have better stopping power, don't fade like drum brakes, work when wet and are easier to service. You can't compare semi trucks to passenger cars or light trucks, totally different.
Since the trucks rear brakes need complete rebuilding along with new drums the cost and work involved to convert is nearly the same. So converting is a no brainer at this point.
I have been continually updating this truck to more modern systems including a third brake lamp, lock up torque converter, modern style wiper arms and blades, lighting, A/C system and more. The brakes are just a continuation of the effort. A hydraboost system in place of the vacuum booster will be next on my list.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2295428
04/28/17 01:43 AM
04/28/17 01:43 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Okay... I just think that for many situations, the drums are adequate. My 1984 Chevy 1/2 ton had a disc/drum setup and braked as well as my 2002 and 2007 Ram 1500 with 4 wheel discs.
Good luck with the build.
Re: Some teaser pics of my rear disc swap [Re: Kern Dog] #2295474
04/28/17 07:06 AM
04/28/17 07:06 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
And both those Dodge / Ram trucks weighed significantly more than that old Chevy
Re: Some teaser pics of my rear disc swap [Re: Morty426] #2295602
04/28/17 01:18 PM
04/28/17 01:18 PM
And not towing heavy.
Re: Some teaser pics of my rear disc swap [Re: Guitar Jones] #2296356
04/30/17 02:16 AM
04/30/17 02:16 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Not tow heavy? Waddaya mean? That Chevy had the bad ass 160 HP 305 !
Re: Some teaser pics of my rear disc swap [Re: Kern Dog] #2297434
05/01/17 10:11 PM
05/01/17 10:11 PM
dogdays Offline
dogdays  Offline
Face it, disk brakes are easier to maintain (no more springs!) and look better. Whether they are more capable isn't the point. I also like the discs' progressive stopping power where braking increases linearly with pedal pressure, rather than the drums tendency to suddenly lock.
Driving my drum brake '64Dog in traffic was a good exercise in defensive driving. Better leave enough room in front!
R.
