Aluminum radiators #2292632
04/23/17 11:48 AM
04/23/17 11:48 AM
Great Neck,LI,new york
hemi-itis Offline OP
There sure are many to choose from.They have tubes in 1 inch,1 1/8 and 1 1/2. Must be 6 companies manufacturing them.My present rad uses the original mopar tanks with a high efficiency core that keeps the heap in the 180* range unless it's really hot out and I'm in line at a show to park,then it might creep to 210*
With all the different radiators available,I thought i would bring it to the MOPARTS court and see what you guys had success with.I do not have room for any puller fans , I have 2 pushers that I have been using for years with no problems.
The reason I wish to change is Jenny Craig sitting on my shoulder guiding me on my diet to loose weight.An aluminum radiator should cool better and save me some weight.
What say YE?? scope
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Aluminum radiators [Re: hemi-itis] #2292639
04/23/17 12:14 PM
04/23/17 12:14 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I have had good luck with my Afco radiator in my GTX. I bought a different one for the Road Runner that looks closer to a stock radiator. Not sure who makes it, but they are sold locally to me.
69 GTX 68 Road Runner
Re: Aluminum radiators [Re: hemi-itis] #2292645
04/23/17 12:25 PM
04/23/17 12:25 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have an generic aluminum radiator from a local roundy round shop and it cools my car great, but I'm not running a blown Hemi. My advice would be to look at large double pass aluminum radiators.
Re: Aluminum radiators [Re: hemi-itis] #2292647
04/23/17 12:29 PM
04/23/17 12:29 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Be careful choosing an aluminum radiator. There is a lot of science behind them, and a lot of lies. Not all radiators work the same. The 1" tube is a good idea, especially if you can use a 2 row. Some companies put them inline, some stagger them for compactness. My thought is that much larger than 1" and, although you are flowing a lot of coolant, not enough is getting any surface cooling for the engine. I think a sacrificial radiator cap is a good idea also. It has an anode sticking out of it that erodes away from acids and/or alkalies that build up in the cooling system.
[image][/image]
Re: Aluminum radiators [Re: hemi-itis] #2292659
04/23/17 12:49 PM
04/23/17 12:49 PM
Thanks sg,this is what I'm looking for.I see prices from $200 to $800,,,,
Re: Aluminum radiators [Re: hemi-itis] #2292784
04/23/17 04:19 PM
04/23/17 04:19 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran a stock never touched 65 rad in y 65.Jack slipped and crunched it good.Evene bent the shroud that is stock.It ran 180 190 all day.Went to a cheap champion off the bay for 150.It runs 180 all day even when its 90 out.I cant believe how well it cools.Only thing I had to do was make a top hose and use a 1 1/2 adapter to 1 3/4 hose for lower.Rocky
Chrysler Firepower
Re: Aluminum radiators [Re: hemi-itis] #2292881
04/23/17 07:23 PM
04/23/17 07:23 PM
crabman173
crabman173
Champion radiators for around $220 delivered are great--they are bolt in and work great--they sometimes come out of the box with a slight 'twist" but they bolt right in Mopars and work--The biggest mistake I see all the time is spending $800 and getting a unit boxed in with electric fans--they block more air than they flow and are just a bad idea for folks that don't understand how simple cooling can be with PROVEN stock design like a real correct shroud, fan clutch, PLAIN ole water pump nothing fancy just no China wrong designed crap impellers--THE BASICS work gang!!
Re: Aluminum radiators [Re: hemi-itis] #2292883
04/23/17 07:32 PM
04/23/17 07:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I cant remember at the moment but either
Champion or American(pretty sure its Champion)
make the Summit brand radiators.. I went with
Summit 3 pass 1 1/8" tubes.. a nice piece
wave
Re: Aluminum radiators [Re: MR_P_BODY] #2292888
04/23/17 07:50 PM
04/23/17 07:50 PM
wave
3 pass eek Thought they only went 2.Sounds like the Champion is the winner. Me go buy! grin
Re: Aluminum radiators [Re: hemi-itis] #2292895
04/23/17 08:00 PM
04/23/17 08:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
wave
As far as I know they make up to a 3 pass radiator..
also understand that "PASS and ROW" mean 2 different
things.. pass is how many times the fluid goes back
and forth.. rows are the number of tubes in each row
and they can be staggered to fit.. some dont understand
that
wave
Re: Aluminum radiators [Re: hemi-itis] #2292957
04/23/17 10:54 PM
04/23/17 10:54 PM
What is the good and bad to multi pass??
Re: Aluminum radiators [Re: hemi-itis] #2292959
04/23/17 10:58 PM
04/23/17 10:58 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
http://www.prcracing.com/aluminum-radiators.html
my latest radiator came from these guys. Was able to call them up, and get the fittings I wanted in the location I wanted.... Just wish I'd pulled the trigger and went AN fittings instead of traditional hose inlet/outlet.
Re: Aluminum radiators [Re: hemi-itis] #2292964
04/23/17 11:08 PM
04/23/17 11:08 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
My biggest concern when getting an aluminum radiator is construction. Epoxied assembled cores are basically disposable. Most radiator shops wont repair them, and welding bungs or making changes to tanks or mounts make me shy away from epoxy cores.
+1 on the sacrificial anode cap. Also, if rubber mounting the radiator, install a ground strap to the chassis.
Re: Aluminum radiators [Re: J_BODY] #2292968
04/23/17 11:14 PM
04/23/17 11:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I bought the basis radiator and welded on a all
the stuff I wanted.. a drain, brackets for the
cooler and mounts for side plates to help control
air going through the radiator and tabs to mount
the thing
wave
Re: Aluminum radiators [Re: hemi-itis] #2292980
04/23/17 11:25 PM
04/23/17 11:25 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I'm not an aluminum welder... was nice to have someone to call, talk to, and have all the above options taken care of. I also had a trans cooler installed in one of the tanks.
Re: Aluminum radiators [Re: hemi-itis] #2293034
04/24/17 01:02 AM
04/24/17 01:02 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
I have a Champion 3 core in my Belvedere. It never gets over 180-190 even last summer in the 90's w/high humidity and hot lapping. I run a factory shroud and derale mech fan and pump.
I bought it from someone her on Moparts. The 1st rad I got was welded very poorly(made 1 call and it was all taken care of. the sent a pick up request and sent the replacement very quickly)
Ok
Re: Aluminum radiators [Re: hemi-itis] #2293079
04/24/17 03:18 AM
04/24/17 03:18 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I was just going to post a question about Northern radiators. I need a rad for my 74 Challenger. There is a sale on Northern aluminum rads up here right now. $275Cdn. 3-core i think, looks decent enough. Anyone?
Re: Aluminum radiators [Re: Pale_Roader] #2293083
04/24/17 03:39 AM
04/24/17 03:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I stand corrected... the Summit ones are Northern
and not Champion.. thats what I have.. they are
all welded.. no epoxy.. I like mine.. I have been
on the road with it in 93* temps and running down
the road at 75-80 mph and the temp stayed at 185*
with a 170* stat and thats with a 518 trans that
had a pretty high slippage rate (10%).. would I
buy another... yep.. in a blink.. well worth the
price
EDIT
I had to go through all my paper work to see where
that radiator came from.. it was Northern
wave
Re: Aluminum radiators [Re: hemi-itis] #2293098
04/24/17 07:07 AM
04/24/17 07:07 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
I run AFCO in my sateLite and a mates 65 belvedere . I have also fitted champion in a 69 roadrunner . Champions dont seem to mount a stock shroud real goid , bracket wrong . With the genetic afco i had brackets wrlded on , plus rotated bottom hose outlet
Never had issues with my 68 , i run the Mopar 5 blade clutch fan stock damaged shroud plus a 12"manual controlled pusher fan
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Aluminum radiators [Re: hemi-itis] #2293124
04/24/17 10:16 AM
04/24/17 10:16 AM
moparx Offline
moparx  Offline
this may sound a little off, but have you considered cutting the support to allow the radiator to sit forward of it's original mounting point, then adding a puller fan setup ? you may not be able or wanting to, but in my opinion, a puller setup will be much better, and moving the radiator ahead should allow the fan setup to clear your pulley setup. that is provided there is enough room to do this. just a thought.
beer
