Re: 470 ci project underway
[Re: ccdave]
#2292689
04/23/17 01:23 PM
04/23/17 01:23 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
Did you buy your so called ARP studs yourself or did your machine shop ? Never seen ARP main studs without the hex key insert on the ends. I never put any lube on the main caps , aluminum or iron.
[Re: ccdave]
#2292776
04/23/17 04:07 PM
04/23/17 04:07 PM
rowin4
Ok, your ARP studs are special to use a girdle. My girdle use's ARP studs with the hex key insert. Did you read what you wrote about the lube between the caps? It doesn't make any sense. It sounds like you took what you wanted to hear from a lot of different answers . Good luck with your build, your going to need it.
[Re: ccdave]
#2293020
04/24/17 12:27 AM
04/24/17 12:27 AM
Posts: 43,254 Bend,OR USA
Cab_Burge
Have you ever had to help educate any type of engineers? I have, some are great, most are normal and some have their suspicions that they are smarter than you are if you don't have a higher education degree than they do Some of them your wasting your time and breath on trying to help them Just like many people in every day life You need to know and remember that many teachers teach thing they can't make a living doing :scope Professors teach teachers My last World block that was suppose to have ARP main studs didn't Trust and verify
[Re: ccdave]
#2293067
04/24/17 02:33 AM
04/24/17 02:33 AM
Posts: 52,972 Romeo MI
MR_P_BODY
On my SB main studs I have both the hex and non hex style.. I dont know if they have a different P/N or not.. never really mattered to me... and I lube everything..I do wipe things on the final assembly but there is still oil and it gets primed while still on the stand.. oil is a good thing
Re: 470 ci project underway!! Crank install
[Re: ccdave]
#2294475
04/26/17 01:08 PM
04/26/17 01:08 PM
Thumperdart
State of confusion
[quote=ccdave] Thanks Ron Moparts is very helpful. I've gathered a ton of good info from a few over the years. I've always wanted to build a 470 and finally have the opportunity to build one for a friend. I really believe it's one of the best combos for a low deck Mopar. Great combo for sure and a BLAST on the street..............
[Re: Thumperdart]
#2294819
04/27/17 01:47 AM
04/27/17 01:47 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[quote=ccdave] Thanks Ron Moparts is very helpful. I've gathered a ton of good info from a few over the years. I've always wanted to build a 470 and finally have the opportunity to build one for a friend. I really believe it's one of the best combos for a low deck Mopar. Great combo for sure and a BLAST on the street.............. Yes Thumper your car is sure proof of that. Ron
