Page 135 of 180 1 2 133 134 135 136 137 179 180
Re: Real world weight loss program and it` cost.......... [Re: Cab_Burge] #2291763
04/21/17 08:15 PM
04/21/17 08:15 PM
fullmetaljacket Offline
never heard of greenlee.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2291776
04/21/17 09:01 PM
04/21/17 09:01 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
Greenlee
I have been using them for years. If you use the large one get the hydraulic ram. Trust me on that.
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS
68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam
65 Chrysler 300 Convert. project
57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son
2003 Dodge Dakota R/T "DEAD"
Re: Real world weight loss program and it` cost.......... [Re: Bob J] #2292009
04/22/17 10:32 AM
04/22/17 10:32 AM
moparx Online content
moparx  Online Content
how "large" is large when the hydraulic ram is needed ? i know of some that are available, but i think the biggest is 1 1/2". [?]
beer
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292046
04/22/17 12:41 PM
04/22/17 12:41 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I think Harbor junk sells a cheap hyd ram.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292054
04/22/17 12:55 PM
04/22/17 12:55 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Stopped my SUPERSHAFTS http://www.supershafts.com/ yesterday to give Mart the heads up on shortening my drive shaft.I left there knowing an aluminum shaft is in my near future.I also picked up my new to me aluminum oil pan. boogie
Pic's from my FLIP PHONE!,,,lol
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Real world weight loss program and it` cost.......... [Re: moparx] #2292090
04/22/17 01:53 PM
04/22/17 01:53 PM
Colorado
Bob J Offline
Bob J  Offline
Colorado
beer
I know that they make 2" punches maybe larger. I'm trying to remember the ram kit that we had at my last TV station and what was the largest size in that. When you make more than one or two holes or once you go larger than 1" you will wish that you have the ram. I only have have up to 1 1/4" and only use a wrench. If you are making a row of holes that is were the ram comes in. I uses these all the time for chassis mounting male and female XLR connectors and DB 9 connectors in equipment. That is how I started to use Greenlee punches 30 years ago building racks in studios. SO I started to us them to make firewall holes that look factory and that holds a grommet tight. That said I have been giving my drill press and workout at slow speed and cutting fluid with my hole saws on the thicker metal. I took out 1 LBS off the ebrake assy with the drill press.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2292296
04/22/17 07:46 PM
04/22/17 07:46 PM
Al, that is a nice looking pan. Is that an 8 Qt or more?
Who's pan creation is that?
Those heads sure look like they have the most raised ports I've seen this side of the East River.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2292305
04/22/17 08:08 PM
04/22/17 08:08 PM
Here's a proud sneak peak flick of my boys new lightweight project to hit the mainstream this Summer. Come to find out through Special K that these 62's are super light compared to the 63-65's to begin with. Do your homework folks.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2292349
04/22/17 09:12 PM
04/22/17 09:12 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Ye Olde TIG welder hath bequeathed it's bounty.
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2292362
04/22/17 09:42 PM
04/22/17 09:42 PM
Lots of aluminum bead added in those welds and might have made those heads as heavy as iron units. LOL.
That thing should fly when all tuned.
I won't let Itis go to the track unless he shaves and shaves at least 100 Lbs off that pup.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292405
04/22/17 11:24 PM
04/22/17 11:24 PM
hemi-itis Offline
hemi-itis  Offline
Only 100 lbs grin I'm thinkin closer to 125 lbs. boogie
Setting the engine back a few inches is like putting a few hundy in the trunk weld
The oil pan is a donation from an out east freind ,the aluminum strut rods were close to a donation also. bow
Greg asked what the double oil filter with the lines weigh,they will not be going back on and neither will the accumulator.One of you guys need to bring a scale SOON.I'd like to weigh the iron & aluminum heads and some of the now debris that's on the floor! bondo
I have to make Jenny PROUD! lock beer
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2292457
04/23/17 12:32 AM
04/23/17 12:32 AM
Can the new combo run without the double filter and accumulator?
if so, that's quite a few pounds right there along with the extra quart or so of petro. The oil pan alone is an extra quart or two it seems.
My Ohio USA scale only reads up to 60 Lbs and I'm afraid that iron head is at least 70-80 Lbs with all the bells and whistles.
The only thing that may be misleading in your case is that a few good things were done at the same time, so when the good results roll in (and I know they will) we really won't know which trick or combo of made it happen.
My opinion: The engine set back is a big plus even if you would not had shaved weight at all and with the old combo. The new aluminum heads on the flow/velocity side will be another benefactor aside from their lesser weight.
Al, I believe that you will be scootin' once everything is settled and nestled in.
There's another cat on here that has benefited impressively from just weight loss and nothing else. I'll respectfully let him zone in here with his results when ever he's ready.
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292476
04/23/17 01:00 AM
04/23/17 01:00 AM
hemi-itis Offline
hemi-itis  Offline
When he comes out from the haze I hope he starts his own thread on that build.
I ordered another piece of 1 1/8 tube last tuesday that was supposed to be in yesterday madNow they say tuesday.After the header tubes are rearranged the block can come back out and let the progress BEGIN!
This heap will finally go the way it should whistling
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292480
04/23/17 01:06 AM
04/23/17 01:06 AM
hemi-itis Offline
hemi-itis  Offline
FMJ,say hello to my new filtration system.It was on the shelf with the aluminum heads for 25 years.The system 1 flows 30 GPM and will be mounted by the oil pump to minimize the length of the oil lines.
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2292513
04/23/17 02:17 AM
04/23/17 02:17 AM
Is that a serviceable/replacement filter element unit?
It looks like a vintage funny car part or something. Never seen that before.
At least the housing is aluminum to keep its weight down.
Re: Real world weight loss program and it` cost.......... [Re: fullmetaljacket] #2292613
04/23/17 11:15 AM
04/23/17 11:15 AM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Kinda goes with the 'top fuel' heads... biggrin
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: Thumperdart] #2292618
04/23/17 11:26 AM
04/23/17 11:26 AM
hemi-itis Offline
hemi-itis  Offline
Indeed it is a cleanable cartridge and still available today.
http://www.insidetopalcohol.com/threads/is-a-system-1-oil-filter-worth-a-hit.25807/
It's funny how we accumulate stuff in the garage and sorta forget that it is there.My guess for the double oil filters with housing and accusump with all the steel braided lines when they are full of 20-50 is 25 lbs. Oil pan maybe 5 lbs work
Re: Real world weight loss program and it` cost.......... [Re: hemi-itis] #2292642
04/23/17 12:15 PM
04/23/17 12:15 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
eek
'71 Duster
'72 Challenger
'17 Ram 1500
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2292656
04/23/17 12:46 PM
04/23/17 12:46 PM
hemi-itis Offline
hemi-itis  Offline
eek
YOU asked,,,,,,,a while back grin
Re: Real world weight loss program and it` cost.......... [Re: RMCHRGR] #2292676
04/23/17 01:11 PM
04/23/17 01:11 PM
State of confusion
Thumperdart Offline OP
State of confusion
eek
Not only that but w/a marginal oil system as in stock on my Dart, it had low pressure and just seemed like a waste but not sure about the MIGHTY HEMI............ beer
