Re: Powder coating a dual snorkel air cleaner
[Re: rutro]
#2291772
04/21/17 08:54 PM
04/21/17 08:54 PM
Posts: 26 Detroit, MI
CCPcoatings.com
Detroit, MI
I'm planning on powder coating my 70 dual snorkel air cleaner. Will the temperature used to bake the paint damage any of the parts in the pods that control the flaps inside the snorkels? Or any temperature switch thing on the bottom of the air cleaner? Thanks guys! Mark Not sure what is in them. In that they were made for an "under hood engine environment" its likely the diaphragms are able to take some heat, but I can't say for sure since I've never had one in my hand. They're going to see between 350F-400F to cure the powder coating so in "most" cases standard plastic parts will not survive.
[Re: rutro]
#2291775
04/21/17 09:01 PM
04/21/17 09:01 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Any reason you are committed to powder coating? I used regular wrinkle paint (Eastwood I think) on my 70 dual snorkel and it turned out great. 10 years later it still looks brand new.
An air cleaner generally doesn't get much wear and tear. Why take the risk of baking the powder at high temp when you don't need to?
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2291780
04/21/17 09:10 PM
04/21/17 09:10 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Wrinkle powder coatings generally require more heat for curing than other powder finishes. It has to do with the chemical reactions required to create the wrinkle look and they like a shock of high heat in order to get things going.
So you're air cleaner will see heat in the 400 degree range for up to 20-25 minutes.
Because of this I've tried to steer customers away from powder coating any assembly with dampers, diaphrams, etc. unless the parts can be removed. If the parts don't melt they may end up very brittle and fail quickly once in use.
Lead, follow or get the hell out of the way
[Re: wingman]
#2291919
04/22/17 01:41 AM
04/22/17 01:41 AM
Posts: 1,458 oklahoma
forphorty
oklahoma
An air cleaner generally doesn't get much wear and tear. Why take the risk of baking the powder at high temp when you don't need to? I'm thinking the same thing
[Re: forphorty]
#2292976
04/23/17 11:24 PM
04/23/17 11:24 PM
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Yep, I don't think any of the dual snorkel (or single snorkel for that matter) air cleaners were wrinkled. The OP didn't actually mention a wrinkle finish. http://www.nicksgarage.com/aircleaner.htmHe mentioned 1970. In 1970 the dual snorkel big block non-air grabber were wrinkle black. Other years varied.
[Re: 1970A13]
#2293605
04/25/17 12:52 AM
04/25/17 12:52 AM
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
well what is the conscious on the {pods} wrinkle or not?? Just like the engine, the factory painted the air cleaners all at once after they were assembled. So the pods got the same paint as the rest of the air cleaner. The pods were held on with little bent metal tabs--put on before paint. If they would have tried to assemble them after paint, the paint would have all flaked off and would have been much harder to assemble that way. Don't believe me check out the later 73 air cleaner that was orange. Pods were also orange--painted all at once.
