Page 3 of 3 1 2 3
Re: smashing out stuck pistons [Re: mro] #2291168
04/20/17 07:19 PM
04/20/17 07:19 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
Will go try again right now - i have about an hour to work it
68 Satellite Wagon and a few other ones
Re: smashing out stuck pistons [Re: mro] #2291170
04/20/17 07:22 PM
04/20/17 07:22 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I am visualizing a multi-ton hydraulic floor jack with some type of arrangement with a chain to strap the block to the jack,,,or some other mechanism to make it immovable,,,and a very stout metal (metal pin or some such) held against the pistons from top or bottom. And the other end against the jack pedestal.
Something like placing block onto a hydraulic press and pressing them out. Have no idea how to manipulate and manage a block of several hundred pounds onto a press,,,,perhaps possible using a cherry picker,,,or perhaps the heavy duty jack idea may do it. Under extreme pressure and a few well placed slams with a big hammer may work things loose.
As I said, just visualizing.
Don't give up.
Likely you have checked out all the heavy duty liquid wrench type products. There are a wealth of them. I have often read of auto transmission fluid mixed with acetone that some swear by.
Re: smashing out stuck pistons [Re: mro] #2291213
04/20/17 08:48 PM
04/20/17 08:48 PM
P
Porter67 Offline
Porter67  Offline
P
Sounds like a trip to the ER just might be in the mix here.
Re: smashing out stuck pistons [Re: mro] #2291215
04/20/17 08:49 PM
04/20/17 08:49 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I have and idea that might work, as with bearing races that you can't drive from behind for one reason or another.
Drill a large enough hole in the center of the piston to get a hacksaw or Sawsall in and carefully work your way to the perimeter of the piston, use a hand file or hacksaw blade to do the last few thousands so you don't mar the cylinder walls.
With the piston's integrity thus diminished, it may free up the circumference and release itself??
Good luck, I'd really like to get my nose in there with you as I love a challenge, Joe
Re: smashing out stuck pistons [Re: mro] #2291222
04/20/17 09:03 PM
04/20/17 09:03 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I like the idea of the bottle jack sitting on a block of wood across the bores. That is the easiest and safest method I've seen in this thread.
It uses the strength of the piston by pulling on the piston pin.
- Stu Harmon
Re: smashing out stuck pistons [Re: Porter67] #2291249
04/20/17 09:41 PM
04/20/17 09:41 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
grin Now that's funny, the idea not if it actually happened. eek
Careful, your character's showing!
Re: smashing out stuck pistons [Re: mro] #2291258
04/20/17 09:54 PM
04/20/17 09:54 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
OK - I really actually beat the living hell out of one. It moved about a 1/16 - or at least thats what it looks like between the rod and crank. Probably not a great question but it there a way of cutting the connecting rods without destroying the cylinder walls ? If I can remove the crank I can hit these right
Re: smashing out stuck pistons [Re: mro] #2291259
04/20/17 09:56 PM
04/20/17 09:56 PM
Lynch Road
mro Offline OP
mro  Offline OP
Lynch Road
The pitting on the lower walls is horrible. This might all be a waste O time.. will post a pic
Re: smashing out stuck pistons [Re: AndyF] #2291260
04/20/17 09:57 PM
04/20/17 09:57 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Originally Posted By AndyF
You can't get any pistons out? You should have a least a couple of pistons near TDC at any one time so work on those first. Take the rod caps off and tap out the rod bolts so you don't scratch anything and then pop those pistons from below. Once you get those guys out move on to the next couple of pistons that you can get to. Once you get 3 or 4 easy ones out you might be able to rotate the crank and get the next ones out.
This, and what Andy said earlier.
I've had pistons that I could not remove with a 2 ton hydraulic jack but I could beat out.
If you have not hit it hard enough to bust out the piston top, you have not hit it hard enough. You have to use a sledge hammer, unless you are a really big guy that know how to swing a 3 lb hammer.
Re: smashing out stuck pistons [Re: mro] #2291279
04/20/17 10:24 PM
04/20/17 10:24 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
I have used an acetylene torch to cut the connecting rods on a 383 to get it apart.
Re: smashing out stuck pistons [Re: mro] #2291331
04/21/17 12:00 AM
04/21/17 12:00 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Good bar. Bigger hammer. You will get it.
Re: smashing out stuck pistons [Re: mro] #2291377
04/21/17 01:21 AM
04/21/17 01:21 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Wont lye dissolve the aluminum? 55 gallon drum with the block in it for a week or two...or more
Re: smashing out stuck pistons [Re: RTSrunner] #2291490
04/21/17 11:46 AM
04/21/17 11:46 AM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
You guys are overthinking this. It isn't brain surgery or rocket science. Take a small steel rod or a piece of pipe and a 4# beater, go from the bottom and take the tops out. The rest will follow.
Re: smashing out stuck pistons [Re: 6PakBee] #2295852
04/28/17 11:39 PM
04/28/17 11:39 PM
blewbyu Offline
blewbyu  Offline
Got my pistons out today. Here is carnage. sawzall
Re: smashing out stuck pistons [Re: blewbyu] #2295899
04/29/17 01:17 AM
04/29/17 01:17 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
As long as you did not hurt the cylinder wall you may be able to use that block....of course aluminum melts at 1270 degrees, so you could have just melted them and had some puddles of aluminum to play with or maybe make some new pistons...
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: smashing out stuck pistons [Re: Polarapete] #2295970
04/29/17 10:25 AM
04/29/17 10:25 AM
blewbyu Offline
blewbyu  Offline
Once the tops were knocked out the pistons came out real easy. up
Cylinder walls look perfect.
Re: smashing out stuck pistons [Re: blewbyu] #2295986
04/29/17 11:20 AM
04/29/17 11:20 AM
North Dakota
North Dakota
A voice, crying in the wilderness.
Re: smashing out stuck pistons [Re: mro] #2296011
04/29/17 12:04 PM
04/29/17 12:04 PM
P
Porter67 Offline
Porter67  Offline
P
Thats great and I see no signs of blood on the floor.
Nice batch of.... destroyed pistons ya got there.
Re: smashing out stuck pistons [Re: Porter67] #2296313
04/30/17 12:05 AM
04/30/17 12:05 AM
blewbyu Offline
blewbyu  Offline
Yes it's a miracle as one time I lost a finger tip pulling a motor out of a car by myself. cry
Think I will keep one around for a conversation piece and when they asked what happen I'll just say too much NOS and blew the top of piston off. drinking
Page 3 of 3 1 2 3
