Page 3 of 3 1 2 3
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2315487
06/03/17 09:02 AM
06/03/17 09:02 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
That's a beautiful car. Great job on the project. Is the interior all that left?
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2316466
06/05/17 09:28 AM
06/05/17 09:28 AM
uk
TiMopar Offline
TiMopar  Offline
uk
Looks excellent!
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2332965
07/07/17 10:39 AM
07/07/17 10:39 AM
Chicago
rocksmopar Offline
rocksmopar  Offline
Chicago
Very impressive looking with the muscle to back it up.
Looking for affordable 72-74 Cuda parts
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2393973
10/27/17 08:44 PM
10/27/17 08:44 PM
Maryland
DaveD Offline
DaveD  Offline
Maryland
The car is looking great, would you be willing to elaborate on the custom tubes you made for the gauges? I think your modification looks really fantastic, but still retains a stock appearance. I would like to something similar if you are willing to share.
Dave D
Re: Pro Touring Twin Turbo 73 Cuda [Re: DaveD] #2402237
11/11/17 11:12 PM
11/11/17 11:12 PM
California
slowfab Offline OP
slowfab  Offline OP
California
Dave,
Sure. I took a piece of PVC pipe the same diameter and cut pieces (sleeves) to length that would put the gauge just past the upper edge of the bezel. The dash trim is angled so it will need to be long enough to extend just past the longest part. I took the sleeves and had them threaded on the inside to match the gauge bezel threads. Remove the stock bezel ring and thread the sleeves on. From there just bond the sleeves onto the dash trim. Be sure to have the gauges tight and level when bonding them as its not too easy to adjust afterward.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2404436
11/16/17 11:55 AM
11/16/17 11:55 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted By slowfab
Here is a view of the magnaflow exhaust from the rear.
Under the rear axle exhaust is certainly not common. If it works I do do like it. Do you have any travel limiters to prevent hard contact, and is it a concern, understanding it sounds like you haven't had much street time yet?
Re: Pro Touring Twin Turbo 73 Cuda [Re: jcc] #2404702
11/16/17 11:44 PM
11/16/17 11:44 PM
California
slowfab Offline OP
slowfab  Offline OP
California
With the air ride there is not near as much axle drop as with a leaf spring car. With the 4 link there is no room to tun a 3" pipe up and around.
Re: Pro Touring Twin Turbo 73 Cuda [Re: slowfab] #2431826
01/09/18 09:23 PM
01/09/18 09:23 PM
Maryland
DaveD Offline
DaveD  Offline
Maryland
Hey thanks for the reply, sorry I took so long to get back but I haven't
been logged in recently
Dave D,
73 Cuda 340/727 currently in process
Page 3 of 3 1 2 3
