Reverse Brake Bleeding on the Cheap! #2290804
04/20/17 12:56 AM
04/20/17 12:56 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I'm ready to bleed the brakes on the Bee. I've read about reverse bleeding and it makes tons of sense. Buying a $160 reverse bleed tool makes zero sense. Anyone got a surefire solution for doing it inexpensively?
I’m listening.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2290809
04/20/17 01:14 AM
04/20/17 01:14 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Gravity bleed.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2290813
04/20/17 01:19 AM
04/20/17 01:19 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
On the cars that won't gravity bleed then use the One person bleeder with the check valve.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2290899
04/20/17 10:25 AM
04/20/17 10:25 AM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
An old fashion high quality squirt can, with a hose.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2290945
04/20/17 11:57 AM
04/20/17 11:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
At the shop we had what looked like a large hipodermic syringe.It had a hose attached.Fill with fluid put on open bleeder and push.used it a lot on hydraulic clutch setup as they seemed to be a pain to bleed.As fro brakes I gravity bleed then if not great I bleed with 2 people.I always gravity then close bleeders pump and reopen.Worked good and still do it after doing it at the shop for 30 years.Rocky
Chrysler Firepower
Re: Reverse Brake Bleeding on the Cheap! [Re: therocks] #2290961
04/20/17 12:39 PM
04/20/17 12:39 PM
grocery stores have a large syringe sold for injecting something into turkeys before you cook em. its definitely big enough capacity & the tip appears to be the right size to slip or clamp on a neoprene hose. its cheap, several bucks iirc.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2290969
04/20/17 12:54 PM
04/20/17 12:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Those probally wont work.Got mine at the parts store and it holds and injects quite a bit.Typically food injectors dont hold or inject as much.I have 2 food ones that I use.Lots different than my car one.Rocky
Chrysler Firepower
Re: Reverse Brake Bleeding on the Cheap! [Re: therocks] #2291014
04/20/17 01:55 PM
04/20/17 01:55 PM
dogdays Offline
dogdays  Offline
Russell Speed Bleeders bring it down to a one person operation.
R.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291035
04/20/17 02:49 PM
04/20/17 02:49 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
shruggy
I have no trouble doing it the traditional way.
I have mechanical Aptitude.
I can screw up anything.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291068
04/20/17 04:04 PM
04/20/17 04:04 PM
WA
tman Offline
tman  Offline
WA
Mityvacs are reasonable.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291081
04/20/17 04:41 PM
04/20/17 04:41 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
One quart jar with a lid. Drill small hole in lid the size of a hose that will fit tightly over your bleeder valve. Insert other end of hose into semi snug,,,,not tight fit into the hole in the lid. Make certain that hoses reaches close to floor of jar. Place 3 or 4 inches of fresh brake fluid in jar sufficient to comfortably cover the end of the hose.
Open bleeder valve and pump away on brake pedal.
Pushing down on pedal forces fluid into jar, fluid in jar prevents air from re-entering brake caliper or cylinder when letting up on pedal,,,,except possibly for a very small amount at initial pumps.
Pump brakes until you see no air bubbles in jar fluid,,up to you how you see the jar if by yourself. Close bleeder. Starting from most distant wheel from MC, go to the next.closer one.
Be certain to check MC for fluid regularly and replenish as required.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291106
04/20/17 05:20 PM
04/20/17 05:20 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
This is what wives/girlfriends are for.
Re: Reverse Brake Bleeding on the Cheap! [Re: Commando1] #2291254
04/20/17 09:47 PM
04/20/17 09:47 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Yeah right!...been there, done that! holy bat crap! never again!..talk about an exercise in futility
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291256
04/20/17 09:49 PM
04/20/17 09:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My wife has helped me more than once bleed them and more.As I said gravity usually does the trick.But some need reg bleeding and a few need reverse bled.rocky
Chrysler Firepower
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291288
04/20/17 10:49 PM
04/20/17 10:49 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
I use a pickle jar with a hose in and another hose out to a vacuum pump. I do use gravity bleeding to get it to a point but then use suction to finish it up. Not sure if other brand of pickle jars will work the same or even jars that didn't come with pickles but my money is on the Vlassic jar.
Careful, your character's showing!
Re: Reverse Brake Bleeding on the Cheap! [Re: mopar346] #2291434
04/21/17 05:21 AM
04/21/17 05:21 AM
Spokane Valley, WA
Spokane Valley, WA
Thanks everyone for the replies. Some great ideas here. I actually like the giant Syringe idea best.
I’m listening.
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291504
04/21/17 12:11 PM
04/21/17 12:11 PM
Weatherford, Texas
RapidusMaximus Online content
RapidusMaximus  Online Content
Weatherford, Texas
I use an assistant if someone is around, the rubber hose in the jar method if I can't find anyone to help, gravity bleed if the system is all new, and once I even cut a 2X4 to fit between the seat bottom and brake pedal...pump up the brake, insert between pedal and seat bottom, crack bleeder, repeat as necessary
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291563
04/21/17 02:08 PM
04/21/17 02:08 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Hey Lindy . . . did you guys get it started ?!?!?!???! I would just gravity bleed first, then use the vacuum style pump with jar and should be all good . . .
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291612
04/21/17 03:23 PM
04/21/17 03:23 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
We fought with the brakes on my 92 D250. They did not want to bleed. The power bleeder at work wouldn't do it. MityVac wouldn't do it. Gravity bleeding wouldn't do it.
The only way we could get it done was the old school pedal pumping method. Other ways of doing it just wouldn't move enough volume at a high enough velocity.
- Stu Harmon
Re: Reverse Brake Bleeding on the Cheap! [Re: Big Bad Bee] #2291861
04/21/17 11:53 PM
04/21/17 11:53 PM
I checked my syringes this afternoon & the turkey baster one was 1&1/2 oz and some I bought at the Rocky Manginelli swap meet said something about a catheter tip & are 2 oz. I ain't did too many brakes but bleeding the MC then the fronts then the rears worked so far. On discs I have a helper pump the pedal several times fast to agitate the fluid then with good timing I open the bleeder on his last downstroke. I put a block of wood under the pedal to limit the piston travel to its worn area in the bore & it helps my helper control the pedal movement better.
