Quick Valve Adjustment Question ? #229088
02/18/09 06:32 PM
02/18/09 06:32 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
OK, I've got my pushrods and Hughes Billet hold downs . Now I just need to confirm some clearances. A short time ago a thread was talking about side clearance on the rockers. I now have .025" total between each set of hold downs. Also for hyd roller lifters with a streetcam/motor is .020" to .030" pre-load still good? Thanks for a quick reply as I'm trying to get this done today.
Re: Quick Valve Adjustment Question ? [Re: Classof70Chally] #229089
02/18/09 06:37 PM
02/18/09 06:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
OK, I've got my pushrods and Hughes Billet hold downs . Now I just need to confirm some clearances. A short time ago a thread was talking about side clearance on the rockers. I now have .025" total between each set of hold downs. Also for hyd roller lifters with a streetcam/motor is .020" to .030" still good? Thanks for a quick reply as I'm trying to get this done today.
Thats fine
Re: Quick Valve Adjustment Question ? [Re: MR_P_BODY] #229090
02/19/09 12:20 AM
02/19/09 12:20 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
Well, I got the hold downs "adjusted" by way of a belt sander, it took a while but turned out pretty good for my first time doing this. I got the pushrods installed and it looks like I sized them just about perfect. With .025" of preload (which BTW is exactly 1/2 turn on the Comp SS Magnums) I have one (1) thread showing below the rocker arm bottom. The motor should be ready to install the first part of next week and fire up a few days after that!
Re: Quick Valve Adjustment Question ? [Re: Classof70Chally] #229091
02/19/09 12:58 AM
02/19/09 12:58 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sounds like you have it pretty well set up, I usually
give it a little more pre-load than .025 but if that
works for the lifters then thats fine( I usually go
1/2 to 3/4 turn)
Re: Quick Valve Adjustment Question ? [Re: MR_P_BODY] #229092
02/19/09 11:49 AM
02/19/09 11:49 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks for the input. The lifters didn't list any specs for preload. I can give them another 1/4 turn (3/4 total) which would bring the preload to .035" to .040" . Would this be better, I don't want anymore valve clatter than is necessary.
Re: Quick Valve Adjustment Question ? [Re: Classof70Chally] #229093
02/19/09 11:54 AM
02/19/09 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Try it where you have it set now.... you shouldnt have
any clatter on a hyd
Re: Quick Valve Adjustment Question ? [Re: MR_P_BODY] #229094
02/19/09 11:59 AM
02/19/09 11:59 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
OK, Thanks. Actually when I did the adjustments I went just a bit past 1/2 turn so I'm probably closer to .030 than I am to .025. I'll leave it as is for now.
Re: Quick Valve Adjustment Question ? [Re: Classof70Chally] #229095
02/19/09 03:06 PM
02/19/09 03:06 PM
Tallmadge, Ohio
DRAGSLICK Offline
DRAGSLICK  Offline
Tallmadge, Ohio
What is the part number on your lifters?
Re: Quick Valve Adjustment Question ? [Re: DRAGSLICK] #229096
02/19/09 03:42 PM
02/19/09 03:42 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
They are Compcams # cc8921-16. They are the retro-fit hydraulic rollers.
Re: Quick Valve Adjustment Question ? [Re: Classof70Chally] #229097
02/19/09 08:35 PM
02/19/09 08:35 PM
Tallmadge, Ohio
DRAGSLICK Offline
DRAGSLICK  Offline
Tallmadge, Ohio
Most pro-magnum lifters I have used call for .002 to .004 lifter preload with the engine warm. If you dont have instructions with your lifters you should call comp-cams and check. If they call for .002 to .004 preload and you have them at .025 to .030 your valves will not close all the way.
Re: Quick Valve Adjustment Question ? [Re: DRAGSLICK] #229098
02/19/09 08:44 PM
02/19/09 08:44 PM
Tallmadge, Ohio
DRAGSLICK Offline
DRAGSLICK  Offline
Tallmadge, Ohio
Open my attachment and see if the page from the catalog is big enough to read.
Re: Quick Valve Adjustment Question ? [Re: DRAGSLICK] #229099
02/19/09 11:35 PM
02/19/09 11:35 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
OK, I just accessed the comp catalog lifter section. For their Hi-Tech series of hyd lifters they recommend a preload of .030 to .060, for their Race series of hyd lifters they recommend a preload range of .000 to .030. For their retro hyd roller lifters which I have, they don't make a recommendation . I'll check with their tech line tomorrow. Has anyone else actually used these guys yet or have some info on what the preload on these should be?
