Tell me about fuel pressure gauges-what's good?
#2290330
04/18/17 11:43 PM
04/18/17 11:43 PM
Posts: 17,888 S.E. Michigan
ZIPPY
S.E. Michigan
I've got a tiny one on the regulator, it's slightly better than nothing, at least it tells me Whether I have any pressure at all but it's not accurate. It's liquid filled and changes with the temp. I can put an ice cube on The gauge and watch the pressure reading change lol.
I've seen complaints about the isolator style, has that been ironed out? Are there any tricks to them?
Straight mechanical, non liquid filled is tempting and simple. Not sure I want to mount it to the cowl, though. (I've got an over abundance of boy racer stuff on my Car already)
How about electric? Can I get something like an auto meter electric And expect it to be fairly close?
What have you had good luck with?
Rich H.
Esse Quam Videri
Re: Tell me about fuel pressure gauges-what's good?
[Re: ZIPPY]
#2290344
04/19/17 12:02 AM
04/19/17 12:02 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I like my Autometer electric.. if you want to test it for accuracy you can T in a known mech gauge along with the electric one.. I also liked my isolated gauge.. I tested it also and it was on. just make sure ALL of the air is out if the secondary side(air compresses and will give you a bogus reading EDIT Also dont use a liquid filled gauge.. specially under the hood.. as the filled gauge gets heated up it screws up the reading.. use a gauge thats open to the atmosphere and had a filter so it can breathe
[Re: ZIPPY]
#2290348
04/19/17 12:06 AM
04/19/17 12:06 AM
Posts: 2,256 IL
furious70
IL
I have the autometer isolator setup for my coronet and it always worked fine. I have the Mallory blue puck isolator for the EFI in the Fury and I've never got it to work reliably. Don't know if I just can't get the air out of the line or what. The puck does sit a little higher than the gauge since it hangs off the back of the dr's side fuel rail.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: ZIPPY]
#2290353
04/19/17 12:16 AM
04/19/17 12:16 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I would go electric, check out Speedhut gauges, lots of options. I have not used any of their stuff but I have never heard anything bad about them. I went overboard with autometer stuff 18 years ago with my car, when I decide to rip all that out I will trim it down to the basics with some speedhut guages.
68 Barracuda Formula S 340
[Re: ZIPPY]
#2290498
04/19/17 11:18 AM
04/19/17 11:18 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
I have a mechanical Autometer mounted inside the cowl scoop on my car...can't see it unless you're sitting in the driver's seat. Never been a fan of electric gauges or using the isolator. Liquid filled gauges are crap...I found that out a long time ago w/ the first one I bought.
[Re: ZIPPY]
#2290546
04/19/17 01:37 PM
04/19/17 01:37 PM
Thumperdart
State of confusion
Fuel pressure is actually part of more modern tunes these days keeping it low like 5lbs. then running a bigger .120+ needle n seat to keep aeration under control so accuracy is HIGHLY important imo.............I run the Magnafuel reg fwiw..............
[Re: AndyF]
#2290550
04/19/17 01:41 PM
04/19/17 01:41 PM
MR_P_BODY
One thing that I do like about electric gauges is that you can run multiple senders and just one gauge.. I am reading 2 temps with one gauge unit.. saves space that way.. if I wanted to read more temps I would just have to put in a different switch
[Re: ZIPPY]
#2290553
04/19/17 01:45 PM
04/19/17 01:45 PM
Bad340fish
Tulsa OK
Thumper you crack me up with your EFI hate .
[Re: Bad340fish]
#2290570
04/19/17 02:38 PM
04/19/17 02:38 PM
Thumperdart
State of confusion
Thumper you crack me up with your EFI hate . Seriously, I don't hate EFI I hate the "Just go to EFI" because you can't make a carb work or are too cheap to have a GOOD one built that WILL perform as good or better than EFI...........As we all know I'm NOT a fan of the new generation cars no matter what brand but so what, that's what makes this crazy world go around and I'm not dogging on new stuff cos let's face it, the new stuff flys................I love "lope" and overlap combined w/the smell of gasoline.............
[Re: ZIPPY]
#2290578
04/19/17 02:47 PM
04/19/17 02:47 PM
Posts: 19,377 Las Vegas
Al_Alguire
Las Vegas
Dom keep preachin. I tried it for years on here about fuel pressure and few pay attention. Low pressure big needle and seat and good fuel system go a long a way to making things work. We can change AFR with fuel pressure and float level. But don't expect to get a warm welcome here on that....
[Re: ZIPPY]
#2290594
04/19/17 03:24 PM
04/19/17 03:24 PM
ZIPPY
S.E. Michigan
I'm almost always paying attention. Except for when I ain't here. That's why I want a gauge that actually works.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2290597
04/19/17 03:33 PM
04/19/17 03:33 PM
Al_Alguire
Las Vegas
IMO stay away from Isoltors, they are slow to respond to changes and not particularly accurate. I have used the Autometer electric gauge with some success if you have to have it in the car. Otherwise a good Autometer mechanical gauge is hard to beat mounted on the cowl would be my preference.
[Re: Al_Alguire]
#2290613
04/19/17 04:11 PM
04/19/17 04:11 PM
Thumperdart
State of confusion
Dom keep preachin. I tried it for years on here about fuel pressure and few pay attention. Low pressure big needle and seat and good fuel system go a long a way to making things work. We can change AFR with fuel pressure and float level. But don't expect to get a warm welcome here on that.... All good Al just trying to help w/what has helped us.............
[Re: Al_Alguire]
#2290626
04/19/17 04:37 PM
04/19/17 04:37 PM
MR_P_BODY
Dom keep preachin. I tried it for years on here about fuel pressure and few pay attention. Low pressure big needle and seat and good fuel system go a long a way to making things work. We can change AFR with fuel pressure and float level. But don't expect to get a warm welcome here on that.... Al.. I thought you used a data logger for fuel pressure.. if so thats a electric unit(transducer)
[Re: ZIPPY]
#2290640
04/19/17 05:29 PM
04/19/17 05:29 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I also have the autometer electric, too cheap to buy another gauge, so when I went EFI I just picked up a new sender. When my low pressure gauge reads 9psi it's really 60psi...haha
I second (third?) low pressure for holleys, but that wasn't really the question...
As for EFI hate...I really enjoyed tinkering with the carb, and had it fairly dialed in. I saw no benefit with the EFI in terms of MPG or ET, but I can do the same tuning while driving down the road without smelling like fuel..
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
