Re: smashing out stuck pistons
[Re: mro]
#2291168
04/20/17 07:19 PM
04/20/17 07:19 PM
Posts: 1,107 Lynch Road
mro
Lynch Road
Will go try again right now - i have about an hour to work it
68 Satellite Wagon and a few other ones
[Re: mro]
#2291170
04/20/17 07:22 PM
04/20/17 07:22 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
I am visualizing a multi-ton hydraulic floor jack with some type of arrangement with a chain to strap the block to the jack,,,or some other mechanism to make it immovable,,,and a very stout metal (metal pin or some such) held against the pistons from top or bottom. And the other end against the jack pedestal.
Something like placing block onto a hydraulic press and pressing them out. Have no idea how to manipulate and manage a block of several hundred pounds onto a press,,,,perhaps possible using a cherry picker,,,or perhaps the heavy duty jack idea may do it. Under extreme pressure and a few well placed slams with a big hammer may work things loose.
As I said, just visualizing.
Don't give up.
Likely you have checked out all the heavy duty liquid wrench type products. There are a wealth of them. I have often read of auto transmission fluid mixed with acetone that some swear by.
[Re: mro]
#2291222
04/20/17 09:03 PM
04/20/17 09:03 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I like the idea of the bottle jack sitting on a block of wood across the bores. That is the easiest and safest method I've seen in this thread.
It uses the strength of the piston by pulling on the piston pin.
[Re: mro]
#2291258
04/20/17 09:54 PM
04/20/17 09:54 PM
mro
Lynch Road
OK - I really actually beat the living hell out of one. It moved about a 1/16 - or at least thats what it looks like between the rod and crank. Probably not a great question but it there a way of cutting the connecting rods without destroying the cylinder walls ? If I can remove the crank I can hit these right
[Re: mro]
#2291259
04/20/17 09:56 PM
04/20/17 09:56 PM
mro
Lynch Road
The pitting on the lower walls is horrible. This might all be a waste O time.. will post a pic
[Re: AndyF]
#2291260
04/20/17 09:57 PM
04/20/17 09:57 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
You can't get any pistons out? You should have a least a couple of pistons near TDC at any one time so work on those first. Take the rod caps off and tap out the rod bolts so you don't scratch anything and then pop those pistons from below. Once you get those guys out move on to the next couple of pistons that you can get to. Once you get 3 or 4 easy ones out you might be able to rotate the crank and get the next ones out. This, and what Andy said earlier. I've had pistons that I could not remove with a 2 ton hydraulic jack but I could beat out. If you have not hit it hard enough to bust out the piston top, you have not hit it hard enough. You have to use a sledge hammer, unless you are a really big guy that know how to swing a 3 lb hammer.
[Re: RTSrunner]
#2291490
04/21/17 11:46 AM
04/21/17 11:46 AM
Posts: 10,706 North Dakota
6PakBee
North Dakota
You guys are overthinking this. It isn't brain surgery or rocket science. Take a small steel rod or a piece of pipe and a 4# beater, go from the bottom and take the tops out. The rest will follow.
[Re: blewbyu]
#2295899
04/29/17 01:17 AM
04/29/17 01:17 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
As long as you did not hurt the cylinder wall you may be able to use that block....of course aluminum melts at 1270 degrees, so you could have just melted them and had some puddles of aluminum to play with or maybe make some new pistons...
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#2295970
04/29/17 10:25 AM
04/29/17 10:25 AM
Posts: 4,282 Florida
blewbyu
Once the tops were knocked out the pistons came out real easy. Cylinder walls look perfect.
[Re: blewbyu]
#2295986
04/29/17 11:20 AM
04/29/17 11:20 AM
6PakBee
North Dakota
Once the tops were knocked out the pistons came out real easy. Cylinder walls look perfect. A voice, crying in the wilderness.
[Re: Porter67]
#2296313
04/30/17 12:05 AM
04/30/17 12:05 AM
blewbyu
Thats great and I see no signs of blood on the floor.
Nice batch of.... destroyed pistons ya got there. Yes it's a miracle as one time I lost a finger tip pulling a motor out of a car by myself. Think I will keep one around for a conversation piece and when they asked what happen I'll just say too much NOS and blew the top of piston off.
