question on backspacing #228979
02/18/09 04:33 PM
02/18/09 04:33 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
i am not sure exactly what you guys mean by back spacing,is that the adapter you put on your rear drum in my case, to make the tire and rim stick out farther so it doesnt hit springs, interested because of my upcoming tire changes. thanks
Re: question on backspacing [Re: don b] #228980
02/18/09 04:37 PM
02/18/09 04:37 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Back spacing is the measurement from the rear most side of the rim, to the wheel mounting surface, pretty simple
As for wheel spacers, they are a fix basically for not having the correct offset wheel. If you have wheels with the correct backspacing there is no need for a spacer.
Re: question on backspacing [Re: OzHemi] #228981
02/18/09 04:49 PM
02/18/09 04:49 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
thanks, so then depending on size tire i want to put on i can buy different rims with different back spacing
Re: question on backspacing [Re: don b] #228982
02/18/09 05:01 PM
02/18/09 05:01 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You pretty much need to decide how much room you have to run a certain width wheel, then figure out your backspacing then a tire to suit. (You want to make sure the tire you decide on is suited to the width of the wheel you want or can fit)
Re: question on backspacing [Re: OzHemi] #228983
02/18/09 05:26 PM
02/18/09 05:26 PM
mi
don b Offline OP
mopar addict
don b  Offline OP
mopar addict
mi
thanks
