Horse Play #2289457
04/17/17 03:07 PM
04/17/17 03:07 PM
Indiana
Crabra Offline OP
Crabra  Offline OP
Indiana
I would like to know how much horse power will be gained by removing the power steering on my duster.
Re: Horse Play [Re: Crabra] #2289464
04/17/17 03:18 PM
04/17/17 03:18 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
Not enough to notice while you drive. If you were comparing on a dyno - you might see a little difference.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Horse Play [Re: Crabra] #2289753
04/17/17 11:09 PM
04/17/17 11:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Not enough difference to have to horse around manual steering. Or pay for another steering gear box and steering shaft.
Re: Horse Play [Re: Crabra] #2289778
04/17/17 11:36 PM
04/17/17 11:36 PM
Kirkland, Washington
Pacnorthcuda Offline
The difference in HP would be while you are cranking the wheel agressively. Straight line very little loss.
Re: Horse Play [Re: Crabra] #2289880
04/18/17 03:47 AM
04/18/17 03:47 AM
Cab_Burge Online work
Cab_Burge  Online Work
Most of us that have done the swap from power to manual steering did it for the weight off of the nose of the car, I seem to remember 70 lbs. weight loss, maybe a little less, maybe a little more confused the pump, the two hoses, the fluid and iron power steering box adds up work
You will need to extend or replace your steering shaft in the steering column and get the proper arm for the manual steering box, my luck has been the one from the power steering box won't fit the manual steering box from a different car whiney shruggy
Other guys on here that found the manual box out of the same year, brand and model car they where working on had no problems with correct arm on the manual box shruggy
Re: Horse Play [Re: Crabra] #2290305
04/18/17 10:39 PM
04/18/17 10:39 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Weight difference is supposedly about 35-40 lbs. As far as horsepower loss, I've heard with the wheels straight that it's almost nothing. But then there is this: http://www.hotrod.com/articles/mopar-engines-power-vs-luxury/
Re: Horse Play [Re: Crabra] #2290453
04/19/17 09:06 AM
04/19/17 09:06 AM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
1 maybe 2.... go for it . Totally worth all the effort
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Horse Play [Re: yella71] #2290552
04/19/17 01:43 PM
04/19/17 01:43 PM
X3 on the weight loss bennie especially on the front end (it all adds up).
Re: Horse Play [Re: RapidRobert] #2291070
04/20/17 04:06 PM
04/20/17 04:06 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
On a street style performance car the alternator belt is worth about a tenth to a tenth and half second just taking the belt off. I would guess the Manual steering would be the same PLUS the weight loss. If that kinda thing is worth your effort and expense go for it. For street driving and the ability to park your car keeping them is a good call. To each his own.
TOdd
Re: Horse Play [Re: Crabra] #2291149
04/20/17 06:45 PM
04/20/17 06:45 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
One less potential leak. Header clearance.
Steers about like a 1952 John Deere when done.
Win/win, kinda...
Rich H.
Esse Quam Videri
