Acid Dip A Body? Lightweight Racer? #228938
02/18/09 04:07 PM
02/18/09 04:07 PM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I am thinking of building another 67 Coronet Race car. I have heard back in 65 (and before) there were light weight race cars that had the bodies acid dipped? Is this correct. Is it possible to do that today and if so would it be worth it? Or could weight be saved in other ways. My plan would be 2800 pound 440 auto Dana car. Thanks.
RS23L7 4-Speed
Re: Acid Dip A Body? Lightweight Racer? [Re: Mopar_Mike] #228939
02/18/09 05:55 PM
02/18/09 05:55 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
yeah they dipped them back then...some came out so thin they would have to be braced....
expensive way to go...use of aluminum and fiberglass will get the weight down..like an aluminum firewall...aluminum tubs...trunk metal replaced with aluminum..etc..
fiberglass hood..rear deck...doors and Lexan glass...that should get you down...Im tired already..
Re: Acid Dip A Body? Lightweight Racer? [Re: Mopar_Mike] #228940
02/18/09 06:15 PM
02/18/09 06:15 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
I'd stay was from the acid, put your $ in fiberglass panels.
A pal of mine has a old SRD built 3 link rear Pro Stock '73 Vega. The doors were acid dipped and to prevent them from flexing, boat flotation foam was sprayed in the inside panels. Unfortunately, it was also a place to retain moisture, doors rusted out from the inside.
Re: Acid Dip A Body? Lightweight Racer? [Re: Mopar_Mike] #228941
02/18/09 08:00 PM
02/18/09 08:00 PM
fullmetaljacket Offline
Much easier ways to cut the fat.
Acid dipped cars will almost likely bend and twist beyond repair if dipped. The early 65'AFX cars twisted and could not close doors properly. They were crap in just a few short months.
You'll spend much more $ trying to brace it back to strength and that in itself will put back the weight that was removed.
Besides it being illegal to use certain acids in most states these days, when you do find a facility to perform it, they will not guarantee that the acid will be neutralized enough to keep the car from rusting into the earth again.
An A-body Dana car can be lightened to that magic number of 2800 with a few well thought out remedies. Aluminum, Lexan, Fiberglass, Carbon fiber, Titanium,(if you have those dollars burning a hole in the pocket), Inconel, Stainless steel and the list keeps going.
Remember, that a super light car may be it's own enemy when it comes to stability on the high end.
Re: Acid Dip A Body? Lightweight Racer? [Re: fullmetaljacket] #228942
02/19/09 08:24 AM
02/19/09 08:24 AM
Danville, NH
Danville, NH
Thanks guys for the responses. I agree, fiberglass and Lexan will be the way to go.
RS23L7 4-Speed
Re: Acid Dip A Body? Lightweight Racer? [Re: Mopar_Mike] #228943
02/19/09 09:41 AM
02/19/09 09:41 AM
Southeastern MI.
Q
QuickSilver Offline
mopar addict
QuickSilver  Offline
mopar addict
Q
Southeastern MI.
Mike, Yes there are plenty of solutions to your delima. Give me a call and I can hook you up with anything you can think of. You want aluminum doors for that coronet? I can do it! Start off with a aluminum bumper and bracket set and knock off a quick 50 pounds or so. How about an aluminum hood/ aluminum RO-23 hood scoop and fender set? QuickSilver can deliver! Later,JC.
Re: Acid Dip A Body? Lightweight Racer? [Re: fullmetaljacket] #228944
02/19/09 10:11 AM
02/19/09 10:11 AM
oohhps.
I just realized that you are building a B-body for competition. Well, that is a little harder but fun to do. This is the rule of thumb. Taking things off is easy and inexpensive at first, but shortly there after, it will get pricey when those last hundred or so pounds need to come off.
get creative and or ask many questions to heads of state here.
I'm taking the fifth. LOL.
Joey, what do you mean you have Aluminum doors for a 66-67 Coronet? As far as I know, none were ever made unless you are making some thing different.
Re: Acid Dip A Body? Lightweight Racer? [Re: fullmetaljacket] #228945
02/19/09 10:35 AM
02/19/09 10:35 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Why try and take all the weight out of the car, and then add a heavy truck rear to it? Why not install a Ford 9"? They can be built lighter...
69 GTX 68 Road Runner
Re: Acid Dip A Body? Lightweight Racer? [Re: JERICOGTX] #228946
02/19/09 10:45 AM
02/19/09 10:45 AM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Just start with body that has been in your area all its life. Some of the ones I have seen are pretty...light weight.
Getting old just means you were smarter than some and luckier than others.
Re: Acid Dip A Body? Lightweight Racer? [Re: dannysbee] #228947
02/19/09 10:53 AM
02/19/09 10:53 AM
Danville, NH
Danville, NH
RS23L7 4-Speed
Re: Acid Dip A Body? Lightweight Racer? [Re: Mopar_Mike] #228948
02/19/09 05:13 PM
02/19/09 05:13 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The term back in the day ws "chemical milling". The EPA has either put that process to rest, or it's gone so far underground that no one knows where it's done nowadays.
It's different & more aggressive than the Redi-Strip strip tanks for removing paint.
The Golden Commandos '65 AWB car and the Autodynamics '70 Chally T/A car are probebly the 2 most famous "oops, went too far" stories; there are pics of the Commandos car with the quarters buckled from launching it.
Those cars did indeed have rust problems, because it's very hard if not impossible to get all the chemical out of the nooks & crannies.
Bear in mind that if you replace the firewall and/or floor there are ramifications in the NHRA rulebook. I would think you can find a lot of fiberglass parts for your car, and lexan or polycarbonate windows will cut a bunch of weight too.
Re: Acid Dip A Body? Lightweight Racer? [Re: topside] #228949
02/19/09 05:25 PM
02/19/09 05:25 PM
[qutoe]Joey, what do you mean you have Aluminum doors for a 66-67 Coronet? As far as I know, none were ever made unless you are making some thing different.
He makes them from scratch.
I saw his '63 Dodge front bumpers in aluminum and they are KILLA!
Re: Acid Dip A Body? Lightweight Racer? #228950
02/19/09 05:30 PM
02/19/09 05:30 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Re: Acid Dip A Body? Lightweight Racer? [Re: redruM] #228951
02/19/09 06:22 PM
02/19/09 06:22 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
If you ever look at the Strickler altered wheel base car,look under the drivers seat. Dave had passed on when this car was restored but Stiiles was around. He said that bracket had to be installed because the seat fell thru the floor when the car was transported from Detroit to Pennsylvania.
Doug
Re: Acid Dip A Body? Lightweight Racer? [Re: dvw] #228952
02/19/09 06:59 PM
02/19/09 06:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
GY3, don't forget, RO23 cars were not just built in 67, the first were built in 1965 (which had lightweight steel fenders, not aluminum). The 64 cars had Aluminum noses but were not VIN'd RO23.
Confused yet?
Re: Acid Dip A Body? Lightweight Racer? [Re: topside] #228953
02/19/09 08:08 PM
02/19/09 08:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Can't be done - has to be neutralized by alkaline (baking soda, etc.) wash until water flow-off is 7.0000 PH.
IIRC only 1 or 2 cars were done that way - and all the other simply dissolved.
Boffin Emeritus
Re: Acid Dip A Body? Lightweight Racer? #228954
02/19/09 11:14 PM
02/19/09 11:14 PM
Show us some photos of the aluminum work to the bumpers, doors. A guy here used to make bumpers and other panels out of light gauge steel and seems to have disappeared.
Re: Acid Dip A Body? Lightweight Racer? [Re: ScottSmith_Harms] #228955
02/20/09 12:36 PM
02/20/09 12:36 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
GY3, don't forget, RO cars were not just built in 67, the first were built in 1965 (which had lightweight steel fenders, not aluminum). The 64 cars had Aluminum noses but were not VIN'd RO.
Confused yet?
Fixed it for you Scott!
'65 RO51
'67 RO23
