Acid Dip A Body? Lightweight Racer?
#228938
02/18/09 04:07 PM
02/18/09 04:07 PM
Posts: 4,283 Danville, NH
Mopar_Mike
Danville, NH
I am thinking of building another 67 Coronet Race car. I have heard back in 65 (and before) there were light weight race cars that had the bodies acid dipped? Is this correct. Is it possible to do that today and if so would it be worth it? Or could weight be saved in other ways. My plan would be 2800 pound 440 auto Dana car. Thanks.
RS23L7 4-Speed
Re: Acid Dip A Body? Lightweight Racer?
[Re: Mopar_Mike]
#228939
02/18/09 05:55 PM
02/18/09 05:55 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
yeah they dipped them back then...some came out so thin they would have to be braced.... expensive way to go...use of aluminum and fiberglass will get the weight down..like an aluminum firewall...aluminum tubs...trunk metal replaced with aluminum..etc.. fiberglass hood..rear deck...doors and Lexan glass...that should get you down...Im tired already..
[Re: Mopar_Mike]
#228941
02/18/09 08:00 PM
02/18/09 08:00 PM
fullmetaljacket
Much easier ways to cut the fat. Acid dipped cars will almost likely bend and twist beyond repair if dipped. The early 65'AFX cars twisted and could not close doors properly. They were crap in just a few short months. You'll spend much more $ trying to brace it back to strength and that in itself will put back the weight that was removed. Besides it being illegal to use certain acids in most states these days, when you do find a facility to perform it, they will not guarantee that the acid will be neutralized enough to keep the car from rusting into the earth again. An A-body Dana car can be lightened to that magic number of 2800 with a few well thought out remedies. Aluminum, Lexan, Fiberglass, Carbon fiber, Titanium,(if you have those dollars burning a hole in the pocket), Inconel, Stainless steel and the list keeps going. Remember, that a super light car may be it's own enemy when it comes to stability on the high end.
[Re: fullmetaljacket]
#228942
02/19/09 08:24 AM
02/19/09 08:24 AM
Mopar_Mike
Danville, NH
Thanks guys for the responses. I agree, fiberglass and Lexan will be the way to go.
RS23L7 4-Speed
#228945
02/19/09 10:35 AM
02/19/09 10:35 AM
Posts: 10,021 MN
JERICOGTX
MN
Why try and take all the weight out of the car, and then add a heavy truck rear to it? Why not install a Ford 9"? They can be built lighter...
69 GTX
68 Road Runner
[Re: topside]
#228949
02/19/09 05:25 PM
02/19/09 05:25 PM
[qutoe]Joey, what do you mean you have Aluminum doors for a 66-67 Coronet? As far as I know, none were ever made unless you are making some thing different.
He makes them from scratch.
I saw his '63 Dodge front bumpers in aluminum and they are KILLA!
#228950
02/19/09 05:30 PM
02/19/09 05:30 PM
Posts: 171 Columbus, OH
redruM
Columbus, OH
[Re: topside]
#228953
02/19/09 08:08 PM
02/19/09 08:08 PM
Posts: 4,206 New York
polyspheric
New York
because it's very hard if not impossible to get all the chemical out of the nooks & crannies
Can't be done - has to be neutralized by alkaline (baking soda, etc.) wash until water flow-off is 7.0000 PH. IIRC only 1 or 2 cars were done that way - and all the other simply dissolved.
Boffin Emeritus
[Re: ScottSmith_Harms]
#228955
02/20/09 12:36 PM
02/20/09 12:36 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
GY3, don't forget, RO cars were not just built in 67, the first were built in 1965 (which had lightweight steel fenders, not aluminum). The 64 cars had Aluminum noses but were not VIN'd RO.
Confused yet?
Fixed it for you Scott! '65 RO51 '67 RO23
