How well will this cam work?
#2288897
04/16/17 04:31 PM
04/16/17 04:31 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
Lift 0.590 intake and exhaust Advertised Duration 312 degrees Duration at 0.050 265 degrees Valve overlap 104 degrees Lobe Separation Angle 106 degrees Going to build a 420" or bigger small block. Will be using some ported Eddys on a stock block and don't want to wind it to the moon. Goal is mid 10s at around 3000 pounds. Thanks!
Re: How well will this cam work?
[Re: slantzilla]
#2288921
04/16/17 04:55 PM
04/16/17 04:55 PM
slantzilla
Park Forest, IL
I would like to stay under 7000. I also have 1.6 roller rockers, I know that changes things some too.
[Re: slantzilla]
#2288932
04/16/17 05:08 PM
04/16/17 05:08 PM
slantzilla
Park Forest, IL
Purple shaft. It's been in the for sale section for awhile.
I have a couple sets of NOS Mopar lifters, should be good in that department.
Thanks!
[Re: slantzilla]
#2288944
04/16/17 05:24 PM
04/16/17 05:24 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
mopar 590 cam...duration is actually 272 not 265.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: slantzilla]
#2288953
04/16/17 05:32 PM
04/16/17 05:32 PM
Posts: 570 UK
rb446
UK
I ran that cam in my street/strip '71 Cuda 340 and thought it was quite mild on the street, had a 4200 conv and 4.30's in it though, maxed it at only 6300 on the track, worked well and made 365hp with stock CR and unported 2.02 heads, its nowhere near what you have so exactly how it would behave with ported Eddies and 420ci?...in a word "Tame" but a good choice with .629" w/1.6 rockers less a bit of lash etc., I'd go for it for what you want.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
