Exhaust Flange Leak on stock Manifold #2288445
04/15/17 09:53 PM
04/15/17 09:53 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
Hi. I had a slight exhaust leak at the flange and I replaced both gaskets on both sides. It leaked worse with the new gaskets. I doubled the gaskets and it helped, but it is still leaking. I used the felpro gaskets the 60025. Any other suggestions?
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Exhaust Flange Leak [Re: GTXKARL] #2288449
04/15/17 09:59 PM
04/15/17 09:59 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Make sure the flanges are flat and not bent from use/tightening and use Rem Flex gaskets.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Exhaust Flange Leak [Re: amxautox] #2288482
04/15/17 10:49 PM
04/15/17 10:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
A very thin skim of copper high temp rtv on the gaskets should seal up the bad spots.
One gasket is all you need.
Re: Exhaust Flange Leak [Re: Neil] #2288606
04/16/17 04:20 AM
04/16/17 04:20 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Normally I take a medium flat file and dress the surface, then use some high temp sealer.
Had one car that I had to do a couple of times, the exhaust pipe wasn't bent exactly right and was not sealing good.
Re: Exhaust Flange Leak [Re: sthemi] #2288841
04/16/17 02:28 PM
04/16/17 02:28 PM
take a straight edge or reasonable flat metal rule & see how bad it is warped then drawfile it end to end (move the file back & forth like you are scrubbing clothes on an antique washing machine scrub board, keeping the file level). Remflex gaskets have a good rep on here.
