Page 2 of 6 1 2 3 4 5 6
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228832
02/18/09 05:48 PM
02/18/09 05:48 PM
where its cold and white durin...
2QUICK4U Offline
2QUICK4U  Offline
HEY THUMP,I HOPE YOU GET THAT 9,BUT I THINK YOUR CAR WILL BE 10.00 I THINK YOUR CAR WILL FALL OFF ON THE BIG END,I HAD A DART WITH SIMILAR COMBO AND IT FELL OFF ON THE BIG END.BUT IM KEEPING MY FOR YOU.YOU HAVE TRIED ALOT OF DIFFERENT THINGS AND HOPE YOU PROVE ME WRONG.IF YOU GO ON PSCA WEB SITE,MEL IS LOOKING FOR PEOPLE WHO WANT TO TEST N TUNE BEFORE MARCH RACE.
Re: Shootin for my 9-second slip.....FINALLY... [Re: b1dartsport] #228833
02/18/09 05:50 PM
02/18/09 05:50 PM
State of confusion
Thumperdart Offline OP
State of confusion
It was a couple of things that showed improvement....hitting the chassis dyno to get the afr`s correct, firecore 50 wires, scaling the car, firecore 50 wires, and yes,leaving at 3000 instead of 1500 and of course; firecore 50 wires.
Re: Shootin for my 9-second slip.....FINALLY... [Re: 2QUICK4U] #228834
02/18/09 05:51 PM
02/18/09 05:51 PM
California, USA
P
Phil Saran Offline
Phil Saran  Offline
P
California, USA
Dominic,
If the Dart does not run the number your looking
for, don't sell it, just replace more steel body
panels with fiberglass and get the weight out of
the car.
Phil Saran Parker, Colorado
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228835
02/18/09 05:52 PM
02/18/09 05:52 PM
2QUICK4U Offline
2QUICK4U  Offline
THUMP ARE YOU GOING TO DO THID ON A STREET TIRE OR SLICK?
Re: Shootin for my 9-second slip.....FINALLY... [Re: 2QUICK4U] #228836
02/18/09 05:54 PM
02/18/09 05:54 PM
State of confusion
State of confusion
2QUICK4U, I hope you`re wrong.......my buddy Kevin just called me about Fontucky but that track is a crap shoot as far as the wind/weather for me so far but if sat. doesn`t work out, I`ll be there.
Re: Shootin for my 9-second slip.....FINALLY... [Re: 2QUICK4U] #228837
02/18/09 05:55 PM
02/18/09 05:55 PM
State of confusion
State of confusion
Hoosier qtp`s......and I love em!
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228838
02/18/09 06:16 PM
02/18/09 06:16 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
Good luck!, let us know the results
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228839
02/18/09 06:45 PM
02/18/09 06:45 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
I'd say throw a can of " Motor Honey" in there and you'll be running low 9's in no time..... ...of course...always remember to adjust your dual wave dipsticks before each pass. If you run the style with chromium sliders, you need an oscilliscope, but I am guessing you may only be running the standard mild steel version?...
Good luck and go knock it down !
RIP Monte Smith
Re: Shootin for my 9-second slip.....FINALLY... [Re: CompWedgeEngines] #228840
02/18/09 07:11 PM
02/18/09 07:11 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Get the car certified ,medical checkup ,neck collar,full face helmet,door sill bars,
whatever else it takes.
AND THEN YOU won't go into the 9s
usually 1 warning and booted 2 pass ive heard NHRA
Remember all the money we spend and didn't pickup anything
just kidding goodluck i'm getting close also
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Shootin for my 9-second slip.....FINALLY... [Re: 10 o to go] #228841
02/18/09 07:31 PM
02/18/09 07:31 PM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
As long its getting enough fuel at the other end i think it will be a 9 for sure. My cuda when it ran 9.80s had similar 1/8 mile et. but more 1/8 mile mph.
Re: Shootin for my 9-second slip.....FINALLY... [Re: ChrisJohnston669] #228842
02/18/09 08:02 PM
02/18/09 08:02 PM
State of confusion
State of confusion
Damn, tough crowd.... I have little doubt it will run the number. Remember; 1/4mi car, 4.11`s and I just picked up 6 mph in the 1/8th alone (BEFORE scaling the car) since my last crappy headwind 10.22 et at 129+ in Fontucky. You will all hear the results sat eve or sun morning.....I predict a 9.78@ 135+........dreaming of course but, without dreams life has little meaning.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228843
02/18/09 09:03 PM
02/18/09 09:03 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
9.92...just guessing tho.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Chad Bittle] #228844
02/18/09 09:52 PM
02/18/09 09:52 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
If conditions are the same as your old best, It WILL run;
9.779 at 133.9 mph.
If conditions are worse than before then;
9.831 at 133.2 mph.
Good luck
Re: Shootin for my 9-second slip.....FINALLY... [Re: Chad Bittle] #228845
02/18/09 09:57 PM
02/18/09 09:57 PM
I'm not going to guess, just say that any car that does low tens is WAAAAAY fast. Don't be disappointed if you don't hit your goal, it's still an awesome car.
Re: Shootin for my 9-second slip.....FINALLY... [Re: mopar_to_ya] #228846
02/18/09 09:59 PM
02/18/09 09:59 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
9.87 at 135,,just go get it,,you have earned it.
Re: Shootin for my 9-second slip.....FINALLY... #228847
02/18/09 10:05 PM
02/18/09 10:05 PM
State of confusion
State of confusion
Thankxx guys.......hell, a 9 ANYTHING would be nice at this rate. The one that guesses the closest gets a big mushy kiss from.. Cab Burge.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228848
02/18/09 10:07 PM
02/18/09 10:07 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
If you need a couple of hundredths try using some Q16. You need 4-5 jets sizes bigger but it is worth 30 or so HP.
Re: Shootin for my 9-second slip.....FINALLY... [Re: BobR] #228849
02/18/09 10:11 PM
02/18/09 10:11 PM
State of confusion
State of confusion
I`ve heard good and bad things about that fuel but I just got a 5-gal. pail of trick along w/my special pump gas/110 mix. My tune is damn near ideal Bob so we`ll see how it runs. Have you been keeping tabs on the weather? Still looks a bit shady to me but who knows.
Re: Shootin for my 9-second slip.....FINALLY... [Re: Thumperdart] #228850
02/18/09 10:13 PM
02/18/09 10:13 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Ask Jason about Q16. It's like N2O in a can. Weather for Saturday looks golden. Sunday looks dicey still.
Re: Shootin for my 9-second slip.....FINALLY... [Re: BobR] #228851
02/18/09 11:00 PM
02/18/09 11:00 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
From one purple dart to another Here is one of my slips for comparison:
60 1.379
330 4.030
660 6.277 mph 109.22
1000 8.221
1320 9.886 mph 134.97
