Re: My first A body.
[Re: Crizila]
#2288292
04/15/17 04:18 PM
04/15/17 04:18 PM
Posts: 3,837 Central Missouri Fort Leonard...
mopar65
Picks or it didn't happen.lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Crizila]
#2288369
04/15/17 06:58 PM
04/15/17 06:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Good to hear a new project is in the works. What flavor a-body?
"Just a Bracket car dressed up like a streetcar"
[Re: Crizila]
#2289490
04/17/17 03:58 PM
04/17/17 03:58 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
What brand and year is it?
[Re: Cab_Burge]
#2289843
04/18/17 01:02 AM
04/18/17 01:02 AM
Posts: 43,522 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You finally got a real car! And if I wreck the front I have tons of parts for it... At least tell us the year and model...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Crizila]
#2291520
04/21/17 12:33 PM
04/21/17 12:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks pretty decent.. now its just time and money to get a real nice driver... there are times that I wish I would have built a stock style car that just looks nice.. but I seem to always go crazy and build something else
[Re: Crizila]
#2291639
04/21/17 04:11 PM
04/21/17 04:11 PM
Posts: 20,172 Park Forest, IL
slantzilla
Park Forest, IL
Nice looking Duster John! Check the front end really well, probably has all the bushings rotted out. Check all the torsion bar mounting points too, A bodies rust/break in those areas a lot.
[Re: slantzilla]
#2291673
04/21/17 05:26 PM
04/21/17 05:26 PM
Posts: 7,506 Az
Crizila
Az
Nice looking Duster John! Check the front end really well, probably has all the bushings rotted out. Check all the torsion bar mounting points too, A bodies rust/break in those areas a lot. Thanks Big D. Actually, torsion bar mounts look good. I will look more carefully for cracking in that area. Ball joints are good ( some one has done some work on it at some point in time ). Upper control arm bushing are fare ( will replace them anyway ). Both strut rods are bent and could use new bushings. Do I have to do something with the lower control arms in order to get the strut rods out so I can straighten them? Don't want to change the lower control arm bushings as they seem ok. Still haven't figured out why I can't get the camber in line on the left side ( negative 3 degrees and out of adjustment )? Something gotta be bent, just aint seeing it yet. Could be the frame mounting points? Under body of car ( floors, wheel houses, rear extensions, unibody frames, K frame / mounts, are all rust free. Might consider sub-frame connectors while I am down this far - could need them with that 300 HP nitrous shot to that 225.
Fastest 300
[Re: Crizila]
#2291703
04/21/17 06:33 PM
04/21/17 06:33 PM
MR_P_BODY
Nice looking Duster John! Check the front end really well, probably has all the bushings rotted out. Check all the torsion bar mounting points too, A bodies rust/break in those areas a lot. Thanks Big D. Actually, torsion bar mounts look good. I will look more carefully for cracking in that area. Ball joints are good ( some one has done some work on it at some point in time ). Upper control arm bushing are fare ( will replace them anyway ). Both strut rods are bent and could use new bushings. Do I have to do something with the lower control arms in order to get the strut rods out so I can straighten them? Don't want to change the lower control arm bushings as they seem ok. Still haven't figured out why I can't get the camber in line on the left side ( negative 3 degrees and out of adjustment )? Something gotta be bent, just aint seeing it yet. Could be the frame mounting points? Under body of car ( floors, wheel houses, rear extensions, unibody frames, K frame / mounts, are all rust free. Might consider sub-frame connectors while I am down this far - could need them with that 300 HP nitrous shot to that 225. 99% of the time when its that far out something is BENT in the front end.. look at the frame rail on that side.. doesnt take much.. to be that much out I would say that car was hit in that corner EDIT Years ago I use to do frame straightening on cars of that era and normally it was bent.. if you cant get the front end to get into spec
