Re: My first A body.
[Re: Crizila]
#2288292
04/15/17 04:18 PM
04/15/17 04:18 PM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Picks or it didn't happen.lol
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: Crizila]
#2288369
04/15/17 06:58 PM
04/15/17 06:58 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Good to hear a new project is in the works. What flavor a-body?
"Just a Bracket car dressed up like a streetcar"
[Re: Crizila]
#2289490
04/17/17 03:58 PM
04/17/17 03:58 PM
Posts: 43,248 Bend,OR USA
Cab_Burge
What brand and year is it?
[Re: Cab_Burge]
#2289843
04/18/17 01:02 AM
04/18/17 01:02 AM
Posts: 43,601 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
You finally got a real car! And if I wreck the front I have tons of parts for it... At least tell us the year and model...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Crizila]
#2291520
04/21/17 12:33 PM
04/21/17 12:33 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Looks pretty decent.. now its just time and money to get a real nice driver... there are times that I wish I would have built a stock style car that just looks nice.. but I seem to always go crazy and build something else
[Re: slantzilla]
#2291673
04/21/17 05:26 PM
04/21/17 05:26 PM
Posts: 7,506 Az
Crizila
Az
Nice looking Duster John! Check the front end really well, probably has all the bushings rotted out. Check all the torsion bar mounting points too, A bodies rust/break in those areas a lot. Thanks Big D. Actually, torsion bar mounts look good. I will look more carefully for cracking in that area. Ball joints are good ( some one has done some work on it at some point in time ). Upper control arm bushing are fare ( will replace them anyway ). Both strut rods are bent and could use new bushings. Do I have to do something with the lower control arms in order to get the strut rods out so I can straighten them? Don't want to change the lower control arm bushings as they seem ok. Still haven't figured out why I can't get the camber in line on the left side ( negative 3 degrees and out of adjustment )? Something gotta be bent, just aint seeing it yet. Could be the frame mounting points? Under body of car ( floors, wheel houses, rear extensions, unibody frames, K frame / mounts, are all rust free. Might consider sub-frame connectors while I am down this far - could need them with that 300 HP nitrous shot to that 225.
Fastest 300
[Re: Crizila]
#2291703
04/21/17 06:33 PM
04/21/17 06:33 PM
MR_P_BODY
Nice looking Duster John! Check the front end really well, probably has all the bushings rotted out. Check all the torsion bar mounting points too, A bodies rust/break in those areas a lot. Thanks Big D. Actually, torsion bar mounts look good. I will look more carefully for cracking in that area. Ball joints are good ( some one has done some work on it at some point in time ). Upper control arm bushing are fare ( will replace them anyway ). Both strut rods are bent and could use new bushings. Do I have to do something with the lower control arms in order to get the strut rods out so I can straighten them? Don't want to change the lower control arm bushings as they seem ok. Still haven't figured out why I can't get the camber in line on the left side ( negative 3 degrees and out of adjustment )? Something gotta be bent, just aint seeing it yet. Could be the frame mounting points? Under body of car ( floors, wheel houses, rear extensions, unibody frames, K frame / mounts, are all rust free. Might consider sub-frame connectors while I am down this far - could need them with that 300 HP nitrous shot to that 225. 99% of the time when its that far out something is BENT in the front end.. look at the frame rail on that side.. doesnt take much.. to be that much out I would say that car was hit in that corner EDIT Years ago I use to do frame straightening on cars of that era and normally it was bent.. if you cant get the front end to get into spec
