Re: SB COOLANT RETURN LINES
[Re: A/MP]
#2287905
04/14/17 10:34 PM
04/14/17 10:34 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not really EDIT I'm running 10.4 with W-2s 0n my street 416 and I dont have any issues
[Re: MR_P_BODY]
#2292346
04/22/17 09:05 PM
04/22/17 09:05 PM
Posts: 792 Earth
Rob C
Earth
Not really EDIT I'm running 10.4 with W-2s 0n my street 416 and I dont have any issues At what level would it be good to tap the rear of the intake? Center of the intake?
[Re: Rob C]
#2292355
04/22/17 09:29 PM
04/22/17 09:29 PM
MR_P_BODY
Not really EDIT I'm running 10.4 with W-2s 0n my street 416 and I dont have any issues At what level would it be good to tap the rear of the intake? Center of the intake? I dont know.. I'm at 625 hp for a stock 340 block and its been fine.. I think this is about max hp for a NA engine
[Re: A/MP]
#2292431
04/22/17 11:57 PM
04/22/17 11:57 PM
RapidRobert
Any advantage of tapping an aluminum intake for better cooling while running an iron head SB with 11.5:1 on the street? go to www.moparchat.com then scroll down & click on "circle track chat" then you will see Sanborns' cooling mods that are in a sticky at the top of the page. read thru it & see what you think. It'll take you a spell to get thru all of it.
[Re: A/MP]
#2292493
04/23/17 01:26 AM
04/23/17 01:26 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
If you have the means to do it I would do it, I don't believe its going to hurt anything. I have a 580ish HP W2 416 and I added the extra cooling lines. I don't have any back to back data but it certainly hasn't caused any problems.
68 Barracuda Formula S 340
[Re: A/MP]
#2292500
04/23/17 01:46 AM
04/23/17 01:46 AM
Posts: 1,532 off the grid
340B5
off the grid
I put the lines on my iron headed 11.5:1 374. Probably a waste of $100 in lines and fittings. I didn't notice any real difference.
Yeah, it's got a smallblock.
[Re: A/MP]
#2292533
04/23/17 03:00 AM
04/23/17 03:00 AM
Posts: 4,457 Washington
madscientist
Washington
IIRC, Chrysler claimed that pulling coolant from the center of the W-5 head was worth 15 HP. I beat the crap out of mine on th dyno and actually lost 5 with the coolant pulled from the center cylinders.
I guess I could have spent more time trying to understand why but didn't think it worth the effort. I capped the fittings off and let it go.
[Re: madscientist]
#2292569
04/23/17 08:33 AM
04/23/17 08:33 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Seems to me, if you want the front cyl's to run hotter, take some coolant out before it gets to them, corollary then would also hold, if rear cyls are too hot, starve the front cyls of coolant. Why there is a difference in the first place, would seem to a better place to start, IMO.
edit, this assumes the primary coolant flow enters the head in the rear and moves forward until exiting.
[Re: madscientist]
#2292733
04/23/17 02:48 PM
04/23/17 02:48 PM
Posts: 792 Earth
Rob C
Earth
IIRC, Chrysler claimed that pulling coolant from the center of the W-5 head was worth 15 HP. I beat the crap out of mine on th dyno and actually lost 5 with the coolant pulled from the center cylinders. I remember reading the same thing. But you lost power. Perhaps, to cool? No matter, we do what works and make no excuses or apologies.
[Re: Rob C]
#2292741
04/23/17 02:57 PM
04/23/17 02:57 PM
madscientist
Washington
IIRC, Chrysler claimed that pulling coolant from the center of the W-5 head was worth 15 HP. I beat the crap out of mine on th dyno and actually lost 5 with the coolant pulled from the center cylinders. I remember reading the same thing. But you lost power. Perhaps, to cool? No matter, we do what works and make no excuses or apologies. I should have spent some more time with it on the dyno, but I was there to test other stuff. At lunch one of the guys at the shop asked how much power those hoses were worth. So I decided to cap them and find out. That was in 1999 but IIRC, it seemed like unless I did some modifications to the flow of coolant, you could actually stall coolant rather than keep it moving. I actually thought about moving the lines down to the timing cover but I felt like there was lower hanging fruit to pick.
[Re: A/MP]
#2292749
04/23/17 03:22 PM
04/23/17 03:22 PM
Posts: 11,574 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I did with my W2s. Just seemed to me that pulling hot water out of both ends, rather than running the hot water in the back all the way to the front first, would make the temps more consistent throughout the head. Especially in the area of the center exhaust ports. Plus eliminate any air pockets in the back of the heads. No downsides, nothing but possible benefits? I'm going to do it.
[Re: A/MP]
#2293202
04/24/17 01:31 PM
04/24/17 01:31 PM
Bad340fish
Tulsa OK
When My dad ordered a comp cam for the 416 we built comp recommended a 4-7 swap. They didn't claim any power gains but one of the reasons was to move the hot spot created by 5-7 up near the front so the water can get out quickly as opposed to warming up that whole bank. So that alone seems like justification for the rear exit. IIRC he said the cylinder swap was easier on the crank as well.
[Re: A/MP]
#2293614
04/25/17 01:09 AM
04/25/17 01:09 AM
Bad340fish
Tulsa OK
It's just a cam change, regular 4" crank.
