Re: Question about vacuum advance
[Re: Coke]
#2287851
04/14/17 08:32 PM
04/14/17 08:32 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
It depends on the specific setup. Stock or hot rodded / racing. Some stock setups used manifold vacuum to add advance at idle, many others did not, using ported (aka timed) vacuum instead.
Based on your post, I am going to guess that you have a modified engine?
If so, set vacuum advance for on road driving conditions. Try driving with it as is. If the engine makes a 'pinging' sound under part throttle load, then experiment with changing the vacuum advance is added and also limit the maximum amount. The goal is no pinging at any part throttle.
For idle conditions, there are two options (again, assuming non-stock engine): 1. Connect the vacuum advance to ported vacuum source. Set base timing higher than stock, probably between 14-20 degrees BTDC depending on how radical the engine is. Vacuum advance now will only get vacuum when the throttle moves off-idle.
2. Connect the vacuum advance to manifold vacuum source. a. Setup the vacuum advance move at less than 10 "Hg. Set the base mechanical timing low (like some stock engines). The total of mechanical base plus the vacuum advance will be the normal idle timing. b. Setup the vacuum advance to move above 11 "Hg. Set the base mechanical timing between 14-20 degrees as described in 1.
Which option is easier will depend on the engine and vehicle. Option 2a has one advantage IF your vehicle likes the early addition of vacuum advance. It means the total mechanical advance will not need to be altered much, if it all, to be proper for Wide Open Throttle. Option 1 allows the idle to be set up independent of vacuum advance needs.
It is critical that total mechanical advance (including base timing) is not too high during full throttle, high load. If you hear it ping, it is detonating. Get off throttle and reduce timing.
[Re: Mattax]
#2288223
04/15/17 02:23 PM
04/15/17 02:23 PM
RapidRobert
if you are on ported (my choice) I would hookup the hose/adj its tip in point after the initial/total/springs have been finalized. If on manifold I would want it to come in sooner (CW with a 3/32 allen wrench, start with 2 turns), so the timing is stabilized at your hot in gear idle speed as opposed to it coming in right where your idle vac is as you posted but I ain't up on manifold so I would Google it as there are some really in depth/comprehensive threads on it. I'm gonna try it one of these days as it might be the way to go. Ported was one of Ma's partial solutions to emission regs on for the most part DD engines & your number sounds hotter than stock.
[Re: Coke]
#2288495
04/15/17 11:23 PM
04/15/17 11:23 PM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Thanks both for taking the time for replying. The engine is modified but not radical.440+0.30 ,the compression ratio is very low,Mopar alu heads and a lunati voodoo 60303 cam.I have a 750 holley vacuum sec. that i want to change for a double pump carb.
Yes ,it is hooked over the carb butterflies (ported).Right now,the initial timming is set to 16 degrees btdc.
Car runs horribly until it almost reaches the working temp.No overheating issues. Once it warms up,it fails under heavy acceleration.Is a 4 speed ,if the pedal is violently pressed while running in second gear, it dies for a moment,makes a detonation and spins the tires .
[Re: Coke]
#2288702
04/16/17 12:08 PM
04/16/17 12:08 PM
RapidRobert
if the pedal is violently pressed while running in second gear, it dies for a moment,makes a detonation and spins the tires. Check the float level & the accel pump tip in, (should be an immediate squirt when the throttle moves).
[Re: Coke]
#2288755
04/16/17 12:58 PM
04/16/17 12:58 PM
Coke
Vitoria, Spain
Mattax, I removed the old electric choke and installed a manual one from Holley. However i only use it for starting the engine.Once that it is running,i need to open it,if not the engine stalls. The carb is a 3310 (click on the picture): Both jets are 70.Yesterday i mounted a 4.5 hg power valve. Rpm at idle is around 850 and it falls to 710 if i remove the vacuum advance hose and plug it with my thumb. "Bang" or "Pop" came from the exhaust. Plugs are very black with a lot of coal.Also the car has been at idle most time sine i started it after the rebuild. I did the driving tests on a closed parcel and i only can drive it in second gear as much. I cannot drive it on the road until it pass the thecnical inspection and i contract a car insurance for it. Thanks.
[Re: Coke]
#2288762
04/16/17 01:10 PM
04/16/17 01:10 PM
RapidRobert
Rpm at idle is around 850 and it falls to 710 if i remove the vacuum advance hose and plug it with my thumb. You are in the transition slots. I would definitely check float level/float saturation/pump psi as the black plug as you know is is beyond pig rich which is killing mileage & will wash the cyls. I missed if your initial is in the ballpark. EDIT maybe the excessive idling/goosing the throttle has blackened em to some extent but first I would get your initial up to 15 or more (I run 18 on a bone stock 85 318) with the stock cam adv 4 degrees.
[Re: Coke]
#2288914
04/16/17 04:45 PM
04/16/17 04:45 PM
Mattax
Phila. Pa.
Mattax, I removed the old electric choke and installed a manual one from Holley. However i only use it for starting the engine.Once that it is running,i need to open it,if not the engine stalls. OK. It is difficult to setup a choke, even a manual one. Later you can see if anything can be done by adjusting the fast idle relationship to the choke position. On an older automatic chokes there is a vacuum actuated 'pull off'. When the engine starts running, the choke opens further due to this pull off. Your new manual choke should cover that vacuum hole. I can send or post a picture if you need. 3310-2 Should be a good carb as long as it has new gaskets. Both jets are 70.Yesterday i mounted a 4.5 hg power valve. According to Holley's List, it originally came with # 72 Primary Main Jets, and a 6.5 Primary Power Valve. Neither of these will effect low rpm. Rpm at idle is around 850 and it falls to 710 if i remove the vacuum advance hose and plug it with my thumb. "Bang" or "Pop" came from the exhaust. Just to verify, the vacuum advance hose is going to the capped nipple in the photo you posted? If so, then the only way vacuum is going to that port is that primary throttle blades are open to far at idle. The pop in the exhaust is probably a combination of ignitable mixture (unfired fuel/air) and late ignition timing making it hot enough to fire at or after the exhaust port opens. Based on what you've written, the initial (idle) relationship of the throttle blades to the transition port needs to be brought into correct range. The transition port below the throttle supplies fuel, above it supplies air.* Remove the carburator and visually set the primary throttle blades so between 0.020-.040" of the transition slots show beneath the throttle. WRITE a note to yourself of how much the idle speed/throttle screw can be turned from .020 to .040" This way, you won't have to take the carburator off again to know where it is at. Use a drill bits or spark plug wire gages to estimate the opening. Clean the spark plugs, start the engine (opening the throttles as much as needed to keep it running). Increase the base timing from 16 to 18 or even 19 degrees and see if it will idle when the throttle is brought back down to the .020 to .040" range. You'll have to adjust the idle mixture screws several times as the engine warms up and as you bring the throttle position down. The mix screws can be anywhere from 1/4 to 2 turns out, but something around 1 to 1 1/2 is most common. If this procedure alone does not succeed in allowing the throttle blade to be closed to the proper range, there is another factor we can address. This is the air supply. If the engine idle speed is too low with the throttles in correct position and enough timing, more air can be let pass without opening the primary throttle blades. Traditionally, this was done by drilling a small hole in each throttle blade. Holley did it at the factory on a few carbs. Other places air can be let in is from the PCV valve (using a fixed orifice) or changing/modifying valves. With a vacuum secondary carb like yours, another method is to slightly open the secondary throttle blades. A little bit should not effect the secondary opening performance. Again, WRITE a note of how much you turned the screw. Otherwise you lose the factory baseline.
[Re: Mattax]
#2288934
04/16/17 05:09 PM
04/16/17 05:09 PM
Mattax
Phila. Pa.
*Illustration of proper throttle to transition slot relationship is shown in Mike Urich and Bill Fisher, Holley Carburetors & Manifolds [Holley Part No. 36-73] (HP Books, 1987) pp. 121-2 edit: The section is called Special Procedures for Wild Camshafts. I'll try to link but you may have to google search as links to copyright material are often temporary.
[Re: Coke]
#2292040
04/22/17 12:31 PM
04/22/17 12:31 PM
Coke
Vitoria, Spain
Sorry for the delay. Haven,t got the time for removing the carb this week. That Holley book looks interisting... About the plugged nipple in the picture,it has been always plugged in. The vacuum advance is hooked to the lower port of the carb. subir fotocertificity.comI will post as soon as i remove the carb to check the transition slots.
[Re: Coke]
#2296473
04/30/17 12:59 PM
04/30/17 12:59 PM
Coke
Vitoria, Spain
I did cap the port for checking the initial timing...However you are right.The port where the advance is attached ,takes vacuum under the primary butterfly.I really thought it went above them: Today i had time for removing the carb and taking some pics, The nipple with the rubber cap that appears in my first post picture, is also connected to a hole wich is under the passenger side primary butterfly. As far for the transition slots,as you can see in the other pictures ,the primary show an important portion of them under the butterflies The secondaries are completely covered off for the butterflies : There is a small screw for regulating this on the secondaries: Also have found this ,wich is very useful: http://tmpcarbs.blogspot.com.es/p/blog-page.html?m=1However it talks about the primary transition slots and how much they should to show.Does not mention how much for the secondaries T-Slots.
[Re: Coke]
#2296490
04/30/17 01:21 PM
04/30/17 01:21 PM
RapidRobert
I ain't sure how far the secondary slot should be showing but I would resolve that/bump the initial to 18/can on ported/reduce primary slot length to a "square" & tune from there.
[Re: Coke]
#2296840
04/30/17 10:59 PM
04/30/17 10:59 PM
RapidRobert
I ain't positive but I'm thinking something (throttle blade?) might be bent as I'd sure think they should be equal. Until you find out for sure (& if it needs to be addressed) you would not want any less than a square on the one.
[Re: RapidRobert]
#2296999
05/01/17 09:47 AM
05/01/17 09:47 AM
Mattax
Phila. Pa.
Working through the posts in reverse. Slot lengthsA slight difference in slots is common. 0.015 ? I don't know. Go ahead and see if there is anything to see. Flashing from the machining is possible, slight tweak to the throttle blades? My gut reaction is if nothing obvious, Leave them the alone. A person with lots of experience and skill in tuning the low speed might teven them out by extending the slot or chamfering the blade. But if they are made longer it will make tuning harder. Then the blade may need to be shut more which will result in more slot above the throttle and everything may need to be redone (idle air bleeds and idle fuel restriction). If you want to make a little more even, first measure the width and total length of both. If the shorter one is wider, then leave it alone. Area under the blade will be similar. Initial Position Anywhere from 0.020 to 0.035" of the slots showing under the blade will be correct on an older Holley like this. There is no exact magic number. There is no exact magic shape. WRITE a note to yourself of how much the idle speed/throttle screw can be turned from .020 to .040"This is the adjustment range you can work with while tuning. With this particular carburator, the upper limit with be the port for the timed vacuum. It must not be exposed at idle. Secondary SlotsThey vary depending on the carb and application. On a carb with idle mixture trim screws on all four barrels, some secondary transfer slot may be exposed. On a carb like the 3310, the secondary slots are pretty high up. The secondary idle circuit's job here is to help insure good fueling when the secondaries start to open. It's best to leave the factory setup. However, if there is need to get a bit more air in at idle, cracking them a hair more open is one technique supply the additional air needed. Side note about TMPThe pictures are nice but be careful with anything from Troy! He has some good info but some bad info too. Worst - he won't acknowledge what he doesn't know but will argue ad infinitum. It got so bad he was tossed from Speedtalk forum... that takes real effort. TimingLet's work with what you have. Yes as you figured out, because of the vacuum port exposure, the initial timing was not quite the same as what was set. If you want to try 18 initial instead of 16 that's fine, even 18. The important factor is that it is stable within the idle rpm range. And of course, that it starts easily both hot and cold. (Too much initial timing can make starting more difficult.) You should find that increasing the timing at idle will allow the motor to idle with the throttle blades more closed than you had before. edit: The idle mix trim screws will probably have to be adjusted each time a change is made to the throttle position. The engine should respond to changes in the mix trim screws. edit 2: The engine will not ping driving around at 38*. That's a good test for top end but needs to be done under full load 3rd or 4th gear at wide open throttle. Coke wants to register the vehicle, so wide open throttle can be dealt with later.
