Page 5 of 5 1 2 3 4 5
Re: Recipe for 700hp six pack 440 or bigger- [Re: jbc426] #2286679
04/12/17 10:40 PM
04/12/17 10:40 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By jbc426
I'm going to installing a set of 3 modified 2300 series mechanical secondary carbs (the old Direct Connection Mechanical secondary Race carbs) that flow more than they did stock. Just how much more I won't know for a few weeks. The center 350cfm carb is being replaced with a 500CFM outboard mechanical carb, which didn't have idle circuits in them stock. This is being addressed so it can be used as a center carb. The boosters and barrels are being removed and the carbs are being converted to aerosol booster style by C&S Specialties. They build a lot of race two barrels for the roundy round guys.
Better keep a set of stock carbs on hand in case that experiment doesn't work out.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2286711
04/12/17 11:28 PM
04/12/17 11:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
No way would I be firing up my fresh new build with some unknown carbs.
There would be an m1 with an 850 on it for me.
After the thing had some miles on it, rings properly seated, etc......then the aerosol carbs can get installed and tried.
Re: Recipe for 700hp six pack 440 or bigger- [Re: fast68plymouth] #2287383
04/14/17 12:14 AM
04/14/17 12:14 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I do have a second stock set that was dialed in nicely on the motor before we did the mods I will use to get it broken in. Thanks, Dwayne.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2287771
04/14/17 05:25 PM
04/14/17 05:25 PM
Sweden
ppmracing Offline
ppmracing  Offline
Sweden
440cu .055 over FT piston 80cc chambers Edelbrock NHRA heads 201cc runners 2.08x1,74 valves, custome billet sheet metal intake ( fit under Cuda shaker hood) stock vaccum six pack carbs and roller cam,,,,,,750hp plus horsepower...
Re: Recipe for 700hp six pack 440 or bigger- [Re: ppmracing] #2287810
04/14/17 06:40 PM
04/14/17 06:40 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Impressive. How fast is the car, and what does it weigh?
Re: Recipe for 700hp six pack 440 or bigger- [Re: ppmracing] #2287812
04/14/17 06:42 PM
04/14/17 06:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At what rpm are you turning it to get that power and what
does that custom intake look like.
wave
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2287829
04/14/17 07:33 PM
04/14/17 07:33 PM
A727Tflite Online content
A727Tflite  Online Content
Most guys are spinning them 7500 + in Super Stock. Here is a pic of Chuck Stubecks' manifold - CFE looks very similar. Picture credit to Wes Allison.
Re: Recipe for 700hp six pack 440 or bigger- [Re: A727Tflite] #2287870
04/14/17 09:10 PM
04/14/17 09:10 PM
Sask, Can.
72demon416 Offline OP
Sask, Can.
That manifold looks nice....
I'll throw this question out there again- in case a used set of 440-1's crosses my path- With 440-1 heads the exhaust port is raised but the low deck is ..."shorter" we'll say- do you think there is a chance of using a regular header with that combo. If I didn't have to buy headers that's money that can be spent elsewhere.
Re: Recipe for 700hp six pack 440 or bigger- [Re: 72demon416] #2287876
04/14/17 09:31 PM
04/14/17 09:31 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I believe a low deck with raised ports should fall into the same spot as an rb with standard port. Although I have never made the swap to confirm.
Re: Recipe for 700hp six pack 440 or bigger- [Re: PorkyPig] #2288072
04/15/17 07:37 AM
04/15/17 07:37 AM
Sweden
ppmracing Offline
ppmracing  Offline
Sweden
Runs 9,20 sek weight 3200...
