360 R BLOCK #2286869
04/13/17 07:02 AM
04/13/17 07:02 AM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
I found a 360 R3 block P4532910 it only has 2 bolt mains but comes with 3 milodon 4 bolt slayed caps. I have 2 questions.
1. Are the splayed caps a good way to go on this block?
2. What kind of price would you put on these parts?
Real Men shift for themselves
Re: 360 R BLOCK [Re: 1DGEMAN] #2286886
04/13/17 09:08 AM
04/13/17 09:08 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That's a nice block, 9.6 deck 59° lifter angle. Yes I would have the caps installed, plenty of room to do so. 2500 is the number I would put on a new block unmachined.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: 360 R BLOCK [Re: 1DGEMAN] #2286922
04/13/17 10:21 AM
04/13/17 10:21 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
If the caps are already installed 2500 would be a very good price.
I've installed them on my Engine Master build with W9 heads. The block are plenty strong but require lots of machining depending on what you want to do. RE $$$$$
Roller lifters require the intake side machining in the lifter gallery. You remove the provision for the 3/8 head bolt. Then the lifter area needs help to use standard roller lifters. Again all this is money.
You could just purchase it and sit on it for 5 years. I would be it would fetch 5000 when you decide to sell it. LOL
Re: 360 R BLOCK [Re: 1DGEMAN] #2287070
04/13/17 03:03 PM
04/13/17 03:03 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I think the P4532910 is the casting number, not the part number. My block was P4876797. Sounds like the same block as mine. I wouldn't sell mine for less than $3k since tall deck blocks are hard to find now.
Floyd Lippencott IV
Re: 360 R BLOCK [Re: 1DGEMAN] #2287335
04/13/17 11:03 PM
04/13/17 11:03 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
6796 block was on closeout for $696 back in the day.
Re: 360 R BLOCK [Re: MattW] #2287369
04/13/17 11:58 PM
04/13/17 11:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I wish I took some pictures of the R1 block that my Dad and I used for the 416 in my car. Ryan at Shady Dell has a CNC program to do all that is mentioned above, turned out great!
68 Barracuda Formula S 340
Re: 360 R BLOCK [Re: 1DGEMAN] #2287398
04/14/17 12:26 AM
04/14/17 12:26 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
R1 with W-2s, Geez Clark, did you set out to purposely build the heaviest SBM in captivity??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: 360 R BLOCK [Re: 1DGEMAN] #2287473
04/14/17 02:24 AM
04/14/17 02:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
And people ask why my car is so heavy.........
We didn't really do it on purpose but it was what we had to work with.
Re: 360 R BLOCK [Re: 1DGEMAN] #2287474
04/14/17 02:51 AM
04/14/17 02:51 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Billy! You are speaking sbm quite fluently. You need to lift a W8 head.... it would surprise you smile
Re: 360 R BLOCK [Re: MoparBilly] #2287636
04/14/17 01:02 PM
04/14/17 01:02 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
It's not that heavy Billy.
[img] [/img]
Re: 360 R BLOCK [Re: clonestocker] #2287821
04/14/17 06:58 PM
04/14/17 06:58 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Its heavy, I had to turn the tortion bars up 4 whole turns after switching from an aluminum headed 360.
Re: 360 R BLOCK [Re: 1DGEMAN] #2287840
04/14/17 08:00 PM
04/14/17 08:00 PM
TN
1DGEMAN Offline OP
1DGEMAN  Offline OP
TN
P4532910 is the casting number. I am told it has a 3.91 bore right now and has never been machined. It has sat in a corner of the guys shop for 8 years. It has some surface rust.
Now the next questions I know I will have to sonic it but any idea on max bore on this block? Does Rod Bloomer still have 4.25 360 cranks?
I think I will put this in my 4sp 65 Barracuda street cruiser.
Re: 360 R BLOCK [Re: 1DGEMAN] #2288006
04/15/17 01:12 AM
04/15/17 01:12 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Yes, I talked to him at Indy. He has a 4.25 kit that is drop in, and maybe a 4.5". He was telling me I could go 440ci on a stock 360 block. beer
Re: 360 R BLOCK [Re: 1DGEMAN] #2288957
04/16/17 05:54 PM
04/16/17 05:54 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I don't know the part number or the results of the sonic test on the R1 block I have. But, I do know that we settled on a 4.08 bore and it is safe to 4.12 naturally aspirated.
