Re: Oil temp sensors/drain plug
[Re: Donny]
#2287378
04/14/17 12:08 AM
04/14/17 12:08 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
A 1/2" NF drain plug, which is the most common drain plug size, can be carefully drilled and tapped to 1/8" NPT, which is a common size for electric temp sender units. I don't know of a vendor that sells them - we always just made our own. Since I have access to a lathe, I always use one to drill the hole to make sure it is centered for maximum strength.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Donny]
#2287382
04/14/17 12:13 AM
04/14/17 12:13 AM
RapidRobert
no actual exp on this so just thinking out loud but what about one in one of the oil pipe plugs at the top rear of the (Big) block? If you do rework/add fittings to the bottom drain plug as you know be sure everything is sealed tight.
