Door Lock Rod Clips #2287229
04/13/17 08:09 PM
04/13/17 08:09 PM
Pangaea
B5 Bee Offline OP
B5 Bee  Offline OP
Pangaea
Is there a source for the plastic clip that holds the rod from the key lock to the lock mechanism?
I need one for a 1984 D100, drivers door lock.
I found a Dorman part that appears similar, applications show it's for GM products.
http://www.ebay.com/itm/Door-Lock-Rod-Cl...5-/181810928801
This one shows on the Advance Auto website, correct application, but it is not available.
http://shop.advanceautoparts.com/p/needa...r+lock+rod+clip
Re: Door Lock Rod Clips [Re: B5 Bee] #2287250
04/13/17 08:47 PM
04/13/17 08:47 PM
Wills Point, Texas
Hugh Jorgan Online work
Hugh Jorgan  Online Work
Wills Point, Texas
I just replaced 2 of them last week in a 84 dually. Went to Oreilley's and bought 2 pkgs of assorted clips for GM & Ford. Each pkg had 1 that I needed.
Re: Door Lock Rod Clips [Re: Hugh Jorgan] #2287930
04/14/17 11:08 PM
04/14/17 11:08 PM
Pangaea
B5 Bee Offline OP
B5 Bee  Offline OP
Pangaea
Thanks,
That was a "Huge" help.
For anyone doing a search,
Dorman 75450 clip assortment, $3.99 at O'Reillys.
Although the package does say GM & Ford, the yellow clip fits.
There are two holes on the lock that the rod can go to, use the outer hole, the inner hole will not give enough travel to unlock with the key.
Re: Door Lock Rod Clips [Re: B5 Bee] #2288255
04/15/17 03:07 PM
04/15/17 03:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Good info.
Re: Door Lock Rod Clips [Re: B5 Bee] #2293815
04/25/17 01:21 PM
04/25/17 01:21 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
At the shop I used metal carb clips when I could.They went over the latch and rod went thru then clipped on.Some you can use them some you cant.Still have a supply in the garage I had at work.Rocky
Chrysler Firepower
Re: Door Lock Rod Clips [Re: B5 Bee] #2294122
04/25/17 09:54 PM
04/25/17 09:54 PM
Coastal Maine
Mr onetwo Offline
Mr onetwo  Offline
Coastal Maine
