2006 Dakota. Getting new key with swapped PCM #2285868
04/11/17 03:50 PM
04/11/17 03:50 PM
BC, Canada
Black_Bee Offline OP
BC, Canada
Hey guys
I bought a 2006 Dakota back in November. It only came with a single key, and I have put off having a new one made due to the shockingly high cost ($300+ here in Canada).
Anyway, I finally booked it into the Dodge dealer to get a key made and they just called and told me that they cant program the key because somebody has swapped in a different PCM and the VIN on it doesn't match the truck.
They said that I will need to book the truck in for an additional appointment that could run several hours for them to figure out what needs to be done.
$300 to cut a key is hard to swallow, but adding 2-3 hours of shop time on top of that isn't going to happen... a $600 key becomes a large percentage of what I paid for the truck!
Is there anything else I can do here?
Thanks!
Paul
Paul
'69 Super Bee 383 EFI Turbo
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2285873
04/11/17 03:57 PM
04/11/17 03:57 PM
South Bend
John Brown Online content
John Brown  Online Content
South Bend
Thanks!
Paul
http://hackaday.com/2017/03/29/save-big-by-hacking-your-car-keys/
Re: 2006 Dakota. Getting new key with swapped PCM [Re: John Brown] #2285921
04/11/17 05:53 PM
04/11/17 05:53 PM
BC, Canada
BC, Canada
Awesome link, thanks for sending it my way!
That said, I think I'll pass on trying that! I am a computer programmer, and built my own EFI system, but that looks like too much guesswork to me.
Thanks again!
Paul
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2285994
04/11/17 08:14 PM
04/11/17 08:14 PM
Guitar Jones Offline
You could just have two non chip keys cut and tie wrap the chipped key inside the steering column shroud.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Guitar Jones] #2286194
04/12/17 01:25 AM
04/12/17 01:25 AM
garnett kansas
rhad Offline
rhad  Offline
garnett kansas
my ladder of success is missing some rungs
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Guitar Jones] #2286203
04/12/17 01:43 AM
04/12/17 01:43 AM
BC, Canada
BC, Canada
That is a great idea! My only concern is if something happened to the truck, I wonder what my insurance company would say if they found it set up like that? Probably nothing since its an 11 year old truck that aint worth much...
Thanks!
Paul
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2286215
04/12/17 02:05 AM
04/12/17 02:05 AM
South Bend
South Bend
Putting the old key inside the steering column was suggested in the link I posted. It may have been in the comments at the bottom, but it was there.
So was the suggestion that if the truck was ever stolen, you might not want to tell the insurance co how you had rigged it. whistling
Re: 2006 Dakota. Getting new key with swapped PCM [Re: John Brown] #2286387
04/12/17 01:16 PM
04/12/17 01:16 PM
I didn't read the link, I looked at it but since I would not be interested in hacking into an ECM for any reason I didn't bother. laugh2
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2286827
04/13/17 01:53 AM
04/13/17 01:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Sounds like a scam. Any scan tool and hook up to the PCM and read the vin in it in about 2 seconds.
Likewise, they can reprogram the vin to what it needs to be.
Also, I am pretty sure the 'code' for the key isn't in the PCM, but rather in the body computer that holds the security programming
**Photobucket sucks**
Re: 2006 Dakota. Getting new key with swapped PCM [Re: 70Cuda383] #2286875
04/13/17 07:22 AM
04/13/17 07:22 AM
Once the VIN is written into the PCM it can't be changed. Additionally if the VINS don't match the other modules won't communicate with it.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Guitar Jones] #2286893
04/13/17 09:37 AM
04/13/17 09:37 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Is that a new development? Because lots of pcms have been reprogrammed with a different vin number. I have 3 here for my 98 Dakota. All 3 have been programmed to have the same vin AND serial number, so that my SCT tuner can load my aftermarket engine tune to all of them, giving me spare, ready to go PCMs.
The SCT 'locks' to one PCM at a time, and can only be used on 3 different pcms before it's useless and you have to buy a new one from SCT. If your PCM fails your SCT is automatically useless because even if you have vin changes left on the SCT, you have to plug in and return the first PCM to stock before you can load to a new PCM...something impossible to do if your PCM has an internal failure.
Bottom line, it has been done in the past.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: 70Cuda383] #2287032
04/13/17 02:08 PM
04/13/17 02:08 PM
Maybe SCT has a VIN unlocking feature but the factory tools do not allow it. New PCM's have to have the VIN written into them. It can't be changed. If I get a new PCM that some dealer has returned and already had a VIN written into it then I have to get another one.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2287035
04/13/17 02:13 PM
04/13/17 02:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The PCM repair shop I go to can change the VIN on any unit I bring them. That is why you can swap a bad one for a good one.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Guitar Jones] #2287400
04/14/17 12:30 AM
04/14/17 12:30 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
It's not an SCT thing. In fact, SCT would not appreciate such antics because then you could change a bunch of different trucks to the same thing and use one tuner for all of them.
I don't know what program it is but my buddy who runs an independent shop has the equipment to do it and has to pay a subscription to the factory for access to the service.
Bottom line, it can be done, or at least up to a certain model year it can be done. We may both be right in that older PCMs can be done but newer ones can't.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2287699
04/14/17 03:07 PM
04/14/17 03:07 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
If the pcm was swapped and it was from another truck with security from the factory, the wireless control module would have also had to been swapped from the donor truck in that era. PCM and WCM would have been the two modules that stored and communicated the code between each other. In that ere we (dealer) could not change vin #'s on pcms. Once they're encoded, their done.
I could tell you a long ugly expensive story about losing the pcm and wcm from that era truck. Jumpstart gone horribly wrong.
Re: 2006 Dakota. Getting new key with swapped PCM [Re: Black_Bee] #2294138
04/25/17 10:13 PM
04/25/17 10:13 PM
BC, Canada
BC, Canada
Hey Guys... just a quick update on this.
1. I ordered two aftermarket (but identical looking) keys with remote buttons off of Amazon for like $35 Canadian.
2. I stuck my original programmed transmitter key near the ignition and tried to use one of my non-programmed (but cut) keys, but it just didn't work no matter where I put the programmed key including touching the two keys together. The truck would start for a few seconds and then die.
3. A locksmith was able to program one of the keys with no issue and suggested that the dealer just didn't know what they were doing.
4. I was able to program the third key myself using the truck itself using the original key and the key I had programmed at the locksmith.
Thanks for the advice!
Paul
