Page 1 of 3 1 2 3
How can I get my 440 to wake up!!?? Something's wrong. #2286700
04/12/17 11:17 PM
04/12/17 11:17 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
OK, long story short. GTX is a dog, punch it from a stop and it will just chirp the tires. I can't feel a hesitate or bog it just doesn't have any power (been this way for years).
Here is what it has:
440 .030 over
forged six pack replacement pistons
old (20 years old) 284/484 cam
ported 906's
Edelbrock RPM manifold w/Holley 750 Advenger carb
~18 inital timing, ~34 total
727 w/340 converter
3.55 suregrip.
I know the cam, car weight, converter, and rear end aren't matched the best but it can't even turn over the tires.
Before I painted the car I could get it to break the tires loose through the gears and only thing I changed was the converter. I took out a stock looking converter and replaced it with the 340 converter thinking it would help.
So, is my setup so miss-matched that I'm screwed or do I just need to go out and buy another converter? I would think that this combo should be able to shred the tires with a stock converter????
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286707
04/12/17 11:26 PM
04/12/17 11:26 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Did you feed it breakfast? grin
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286712
04/12/17 11:29 PM
04/12/17 11:29 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I wish it was that simple!!
It sounds GREAT but has no teeth. My small block Demon will blow it off the road!!!
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286716
04/12/17 11:34 PM
04/12/17 11:34 PM
amxautox Offline
amxautox  Offline
How quick does it rev up when it's in neutral? And does it have six pack rods also?
Tom
author unknown
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286719
04/12/17 11:36 PM
04/12/17 11:36 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I learned many years ago to put a decent stall converter behind even the 474 mopar cam on a 440 car. I have not bought one since 1978 but a B&M super holeshot turned the 440 cuda into a tire shredder. I currently have a 500" low deck with a PTC 9.5 and it rocks.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: buildanother] #2286721
04/12/17 11:41 PM
04/12/17 11:41 PM
st.cloud fl
d-150 Offline
Smarter than a 5th grader?
d-150  Offline
st.cloud fl
Did u degree the cam.also 484 likes a 2500 stall
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286722
04/12/17 11:41 PM
04/12/17 11:41 PM
Cab_Burge Online work
Cab_Burge  Online Work
If you have the old converter still put it back in twocents
I don't and won't use any of the newer Mopar Purple Shaft street Hemi grinds, especially the famous 284 street hemi grinds tsk twocents
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: amxautox] #2286727
04/12/17 11:48 PM
04/12/17 11:48 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Seems to be fine in neutral.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: buildanother] #2286728
04/12/17 11:49 PM
04/12/17 11:49 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I have a PTC in the Demon and it rocks!!! I think it flashes around 3700 but I don't want that for the GTX, I'm looking for something a little more streetable if possible.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: d-150] #2286730
04/12/17 11:50 PM
04/12/17 11:50 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I didn't build the engine, it was build 20+ years ago and has about 5000 miles on it.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: Cab_Burge] #2286732
04/12/17 11:51 PM
04/12/17 11:51 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I looked up the part number for the 284/484 cam it in and it's the old one. He gave me a pile of receipts two inches thick for the motor/trans.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286733
04/12/17 11:52 PM
04/12/17 11:52 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I know a converter can really wake up an engine but shouldn't an engine like this be able to put some hurt on the rear tires even with a stock converter?
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286734
04/12/17 11:52 PM
04/12/17 11:52 PM
I would get a cranking compression number & maybe a leakdown also
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286738
04/13/17 12:00 AM
04/13/17 12:00 AM
amxautox Offline
amxautox  Offline
Maybe the '340 converter' isn't really a 340 converter, or it's bound up inside for some reason. If it started doing this right after installing it, I'd say it's the converter. If you don't have the old one, maybe borrow one from somebody before buying a new one, if you don't mind removing the trans a few times.
Tom
author unknown
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286740
04/13/17 12:04 AM
04/13/17 12:04 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How tall are the rear tires? They look tall. Was the cam degreed in? It could be retarded. What type of fan on the engine, solid mount or clutch fan? is the carb a vac secondary or mechanical? What ignition system? How tight are the engine clearances? I agree that your 484 cam likes a converter.
The 484 is not a hemi grind cam. The 474 is and I don't think it works very well at all.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286741
04/13/17 12:10 AM
04/13/17 12:10 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
The tires are 28" (275/60/15) I don't about the clearances, I didn't put the engine together. I don't know that the cam is degreed either.
I have the receipt for the converter and it shows 7642 and I believe the 764 is the 340 converter.
So it sounds like my assumption about a mild 440 being able to smoke the tires with any converter is BS.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286749
04/13/17 12:16 AM
04/13/17 12:16 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd make sure it's getting full throttle first, and if it is.......I'd see if I could borrow a different carb.
I'd be looking for a 750DP if it were me.
As long as the converter isn't broken/defective, and assuming there was a good carb on it, that combo should run pretty good.
I second the thought of doing a compression test on a least a couple cylinders, just so you know where it's at.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: fast68plymouth] #2286750
04/13/17 12:20 AM
04/13/17 12:20 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I took off a 750 DP because I was told the mechanical secondaries were compounding my problem. Unfortunately the carb sold with my barracuda a couple of years ago.
I'll have to compression test.
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286760
04/13/17 12:26 AM
04/13/17 12:26 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
OK, I made one mistake. I looked up the part number for the pistons (2286P) and that shows a stock replacement piston the six-pack piston so my compression is lower. BUT, like I said, when I first got the car it would shred the tires with this same engine...
Re: How can I get my 440 to wake up!!?? Something's wrong. [Re: VITC_GTX] #2286766
04/13/17 12:29 AM
04/13/17 12:29 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Also, I just remembered that I had to back off the timing due to bad predetonation during hard throttle. Still has that problem a little bit. Compression ratio should be good...
Page 1 of 3 1 2 3
