Air pressure and reaction time #2286476
04/12/17 04:42 PM
04/12/17 04:42 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Does anyone had a general rule of thumb as to how much a pound of air pressure in the front tire equates to reaction time increase or decrease,specifically with a 27.5 tire?
Re: Air pressure and reaction time [Re: jst19600] #2286482
04/12/17 05:01 PM
04/12/17 05:01 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Not sure if it affects R/T that much. I thought that the increase in front tire air pressure was to decrease rolling resistance, thus lowering ET.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Air pressure and reaction time [Re: 68LAR] #2286490
04/12/17 05:30 PM
04/12/17 05:30 PM
Locomotion Offline
Locomotion  Offline
It does. I've had to vary it between 50 and 26 lbs. Somebody told me the rough average, but I forgot. But the higher you go, there are diminishing returns - i.e.: 30-35 lbs will make more difference than 35-40 lbs.
Re: Air pressure and reaction time [Re: Locomotion] #2286541
04/12/17 06:44 PM
04/12/17 06:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
True.. as the pressure goes up the dia will change
less at some point.. I could get a small amount of
change inn reaction time.. but not much at all...
I changed from 30-50 psi
wave
Re: Air pressure and reaction time [Re: MR_P_BODY] #2286552
04/12/17 07:02 PM
04/12/17 07:02 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
wave
Well, today wasn't wasted. I learned something new...Thanks..I personally can't see the diameter changing more than an 1/4" at best going from recommended psi to 40 or 50 psi, but evidently I'm not getting it.. Thanks for the info. I run my fronts at 40 psi when racing, 32 on the street.
Re: Air pressure and reaction time [Re: jst19600] #2286569
04/12/17 07:41 PM
04/12/17 07:41 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I can't see any difference. Ive tried numerous times.
Doug
Re: Air pressure and reaction time [Re: jst19600] #2286843
04/13/17 03:10 AM
04/13/17 03:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
What TP is the manufacturers rec when you pump them up to 40 or 50 PSI?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Air pressure and reaction time [Re: jst19600] #2286844
04/13/17 03:29 AM
04/13/17 03:29 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
There's a couple of guy's at the track that play the tire pressure game, one runs one front tire so low the starting line guy has backed him off. He claims he can leave as the 3 yellow comes on . I've watched , he does, he also red lights a lot. Another uses his tire pressure pounds to rpm launch 26 pounds =2600 rpm etc. . Just one mans theory but he wins a lot. Go figure. I just run 35 psi, pull the wheels out of the light on launch and red light.
Re: Air pressure and reaction time [Re: jst19600] #2286900
04/13/17 09:54 AM
04/13/17 09:54 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I used a 2x4 (laid with 4" side down) and a square to figure out how much roll out my tires had with X amount of air. I started at 25 psi and went up to 35 psi, in 5 lb increments. There was a bigger difference between 25-30 than 30-35. I forget the exact measurements but there was 3/32" difference with 5 lbs of air change. Also a "race" tire may change differently than a "street" tire.
Re: Air pressure and reaction time [Re: jst19600] #2286985
04/13/17 12:30 PM
04/13/17 12:30 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I would guess this would make more difference with a bias ply tire than a radial.
Re: Air pressure and reaction time [Re: jst19600] #2286990
04/13/17 12:41 PM
04/13/17 12:41 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Re: Air pressure and reaction time [Re: jst19600] #2287095
04/13/17 03:39 PM
04/13/17 03:39 PM
Georgia
66coronet Offline
66coronet  Offline
Georgia
rear tire pressure has had more of an affect on our cars. we tried it in .25 lb increments. We run 29.5x10.5 W tires on those cars.
Re: Air pressure and reaction time [Re: 66coronet] #2287183
04/13/17 06:36 PM
04/13/17 06:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was gonna try 20psi on my race car but after
lowering it to the 20 I looked at the tires..
I was afraid it would hit the rims on the way
back down from the normal wheel stand.. they
were low.. also on my car I had 3/4" of stagger
on the front end.. the right tire was set back
the 3/4" to give me a littler longer time in the
lights to slow the reaction time.. I used a 24.5"
tall tire and the car reacted very quick.. I was
running a 1.19 60' on a normal basis unless the
tires were getting old(70-70 passes).. the rear
tires were MOST of the time set at 6 7/8 to 7 1/8
psi.. depending on the track.. this pic is with a
lower rpm launch and between the rpm and tire psi
it started rolling/folding the tires
wave
Re: Air pressure and reaction time [Re: DusterKid] #2287346
04/13/17 11:16 PM
04/13/17 11:16 PM
I bought a 10 ft. cloth seemstress tape to check tire circumferences on both my front and rear tires at different tire pressures thumbs scope
I shoot for 1/4 inch vareince on the rear tires, inflate as needed to get that thumbs
Re: Air pressure and reaction time [Re: jst19600] #2287634
04/14/17 12:57 PM
04/14/17 12:57 PM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Im at my limit on front tire size now running 27.5 on my dart.I just put a Gerst tubular front suspension on it and i have the rebound set as soft as i can on the viking shocks to allow for most rise.Im looking to slow things down aprox. .030.I run 28.0 x 10.5 in the back usually at 10 3/4 pressure.I footbrake the car and it reacts very quick.I may try backing off the timing kill it a little off launch.If i tighten the front shocks im assuming that would make it react quicker with less movement up?
Re: Air pressure and reaction time [Re: 68LAR] #2287736
04/14/17 04:18 PM
04/14/17 04:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
wave
I do about the same as I run about 35 on the street and 40 at the track. Does it help any ?? Most likely not much if any. Ron
Re: Air pressure and reaction time [Re: jst19600] #2288442
04/15/17 09:46 PM
04/15/17 09:46 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i also was bulbing a lot and someone told me about slowing my car down reaction time wise with air so i went down to 30 in the front and down 2 in the back and boom i'm at .015. it seems to work. i am on regular bias tires . the rear must wind up the sidewall a little bit more before it rotates the tire and lower in the fromt must make the contact patch a little bit longer.
Re: Air pressure and reaction time [Re: dmking] #2288663
04/16/17 11:28 AM
04/16/17 11:28 AM
Locomotion Offline
Locomotion  Offline
Exactly! It does make a difference. There are variables that often make it difficult to see. A major variable is a driver's "margin of error". i.e.: If a driver can consistently stay within a .03 spread in reaction times, than a change in air pressure that should make an .01 difference may not be obvious. But keeping very detailed, long-term records of all variables will help. This includes different tracks, day/night, possible lane differences & more.
Re: Air pressure and reaction time [Re: jst19600] #2288691
04/16/17 11:57 AM
04/16/17 11:57 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
In my opinion most foot brake guys trying to slow down R/T should look at the driver. Try a pro tree and see where your at. See if you're minus on the full tree and plus on the pro (take out the .100 if its .400 Pro). If so you are anticipating the bottom bulb. You should be within .010 or less difference.
Doug
Re: Air pressure and reaction time [Re: dvw] #2295932
04/29/17 04:19 AM
04/29/17 04:19 AM
Wichita,ks.
jst19600 Offline OP
jst19600  Offline OP
Wichita,ks.
Thanks to my new Gerst suspension i have staggered the front tires 1/4 inch.Havent had a chance to take it to the track yet to see the results in reaction time.
