Another cam question? #228609
02/18/09 12:28 PM
02/18/09 12:28 PM
nc
E
emarine01 Offline OP
E
nc
When someone asks what lobes does the cam have, what exactly are they asking? My cam is a comp chs 296ar6 , dosent say anything about lobe type on cam card ,just lobe lift .4210 and power band 5500 to 7500 in 360cid with the opening & closing timing @.050 , went to comps web site and for lobe it said hi tech? I guess thats better than low tech but doesent mean much to me.
Re: Another cam question? [Re: emarine01] #228610
02/18/09 12:49 PM
02/18/09 12:49 PM
Cab_Burge Online work
Cab_Burge  Online Work
All of Comp Cams have lobe numbers, the lobe numbers are in some of the older Comp Cams catalogs in the back. The Hi Tech roller lobes are a type of lobe in thier catalog. The numbers at the top of the cam card usually identify the grind number and the lobe numbers like CR3 4131B/4020B R 108.0. Look your ups and post it on this post and i will be glad to dig out one of my old Comp catalogs and furnish the lobe specs for you.
Re: Another cam question? [Re: Cab_Burge] #228611
02/18/09 12:56 PM
02/18/09 12:56 PM
nc
E
E
nc
This is a repo fax cam card from comp , the only other number is the part -20-754-9
Re: Another cam question? [Re: emarine01] #228612
02/18/09 01:20 PM
02/18/09 01:20 PM
I looked in both of my Comp Catalogs and that part number is not a shelf grind, try E mailing Comp with that part number and ask them for the cam specs and lobe numbers Let us know what you find out
Re: Another cam question? [Re: Cab_Burge] #228613
02/18/09 01:41 PM
02/18/09 01:41 PM
nc
E
E
nc
Thanks , I will try comp & see whats up ,
Re: Another cam question? [Re: Cab_Burge] #228614
02/18/09 02:09 PM
02/18/09 02:09 PM
nc
E
E
nc
Ok, Intake lobe is 4017b exhaust 4027, what does this mean?
Re: Another cam question? [Re: emarine01] #228615
02/18/09 02:16 PM
02/18/09 02:16 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
4017 is a Hi-Tech .420"............ 296º @ .020"/260º @ .050" .420" lobe lift (B stands for SBM base circle)
4027 is a Hi-Tech .420" EX............. 300º @ .020"/262º @ .050" .420" lobe lift
Re: Another cam question? [Re: S/ST 3040] #228616
02/18/09 02:31 PM
02/18/09 02:31 PM
nc
E
E
nc
Hey vic , pretty cool , you were the one that asked me the lobe question, its a little less agressive than some of the newer rollers ,
Re: Another cam question? [Re: emarine01] #228617
02/18/09 02:36 PM
02/18/09 02:36 PM
S/ST 3040 Offline
S/ST 3040  Offline
You could use a cam with snappier lobes, especially with a 1.5 rocker arm.
Re: Another cam question? [Re: S/ST 3040] #228618
02/18/09 02:41 PM
02/18/09 02:41 PM
nc
E
E
nc
Yea, we are leaving a lot on table with this cam , we need it all by 200ft
