Another cam question? #228609
02/18/09 12:28 PM
02/18/09 12:28 PM
nc
E
emarine01 Offline OP
E
nc
When someone asks what lobes does the cam have, what exactly are they asking? My cam is a comp chs 296ar6 , dosent say anything about lobe type on cam card ,just lobe lift .4210 and power band 5500 to 7500 in 360cid with the opening & closing timing @.050 , went to comps web site and for lobe it said hi tech? I guess thats better than low tech but doesent mean much to me.
Re: Another cam question? [Re: emarine01] #228610
02/18/09 12:49 PM
02/18/09 12:49 PM
All of Comp Cams have lobe numbers, the lobe numbers are in some of the older Comp Cams catalogs in the back. The Hi Tech roller lobes are a type of lobe in thier catalog. The numbers at the top of the cam card usually identify the grind number and the lobe numbers like CR3 4131B/4020B R 108.0. Look your ups and post it on this post and i will be glad to dig out one of my old Comp catalogs and furnish the lobe specs for you.
Re: Another cam question? [Re: Cab_Burge] #228611
02/18/09 12:56 PM
02/18/09 12:56 PM
nc
E
E
nc
This is a repo fax cam card from comp , the only other number is the part -20-754-9
Re: Another cam question? [Re: emarine01] #228612
02/18/09 01:20 PM
02/18/09 01:20 PM
I looked in both of my Comp Catalogs and that part number is not a shelf grind, try E mailing Comp with that part number and ask them for the cam specs and lobe numbers Let us know what you find out
Re: Another cam question? [Re: Cab_Burge] #228613
02/18/09 01:41 PM
02/18/09 01:41 PM
nc
E
E
nc
Thanks , I will try comp & see whats up ,
Re: Another cam question? [Re: Cab_Burge] #228614
02/18/09 02:09 PM
02/18/09 02:09 PM
nc
E
E
nc
Ok, Intake lobe is 4017b exhaust 4027, what does this mean?
Re: Another cam question? [Re: emarine01] #228615
02/18/09 02:16 PM
02/18/09 02:16 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
4017 is a Hi-Tech .420"............ 296º @ .020"/260º @ .050" .420" lobe lift (B stands for SBM base circle)
4027 is a Hi-Tech .420" EX............. 300º @ .020"/262º @ .050" .420" lobe lift
Re: Another cam question? [Re: S/ST 3040] #228616
02/18/09 02:31 PM
02/18/09 02:31 PM
nc
E
E
nc
Hey vic , pretty cool , you were the one that asked me the lobe question, its a little less agressive than some of the newer rollers ,
Re: Another cam question? [Re: emarine01] #228617
02/18/09 02:36 PM
02/18/09 02:36 PM
S/ST 3040 Offline
S/ST 3040  Offline
You could use a cam with snappier lobes, especially with a 1.5 rocker arm.
Re: Another cam question? [Re: S/ST 3040] #228618
02/18/09 02:41 PM
02/18/09 02:41 PM
nc
E
E
nc
Yea, we are leaving a lot on table with this cam , we need it all by 200ft
