BB vs SB weights #228604
02/18/09 12:10 PM
02/18/09 12:10 PM
PA
moparacer Offline OP
PA
Whats the weight difference between a BB with Iron heads and water pump housing and a all Iron Small block?
Both with aluminum intakes......
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: BB vs SB weights [Re: moparacer] #228605
02/18/09 12:53 PM
02/18/09 12:53 PM
Locomotion Offline
Locomotion  Offline
I have heard that it's in the 75-100 lb range. But I never weighed them myself.
A low deck big block (361/383/400) would be a little lighter than a raided block BB (413/426/440. They did make a raised block 383 about 45+ years ago, but not many.
Re: BB vs SB weights [Re: Locomotion] #228606
02/18/09 04:55 PM
02/18/09 04:55 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The RB blocks are in the 220-230 lb range. Don't know about the SB,maybe knowing the BB weight will help you some.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: BB vs SB weights [Re: MRMOPAR622] #228607
02/18/09 06:49 PM
02/18/09 06:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
A bare Smallblock weighs about 165 +/- with caps.
A B motor should weigh about 20# lighter than an RB (imagine 2 cast iron deck plates .75" thick which is roughly the difference between the blocks), but it's not always the case as the early 400 B's are generally a bit thicker inthe main webs.
WIZE
In Car:
Re: BB vs SB weights [Re: Streetwize] #228608
02/18/09 07:41 PM
02/18/09 07:41 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
My .020 over bare 340 block is showing 160# on my bathroom scale.
Don't forget that if you run a small block and an auto you can run a 904 and save another 50#
