Ram 1500 voltage problem #2285874
04/11/17 04:01 PM
04/11/17 04:01 PM
California USA
LowDeck451 Offline OP
California USA
Hey all. I'm having an intermittent problem with my voltage gauge pegging at 18 volts once in a while. The first time it happened I pulled over, took a look, didn't see a problem, then it went back to normal. When it happens, if I shut it off/restart, it's fine. Haven't troubleshot much yet, wondering if it's a common problem some of you might have had and can steer me in the right direction? Thanks! 2000 Ram 1500 5.9
Re: Ram 1500 voltage problem [Re: LowDeck451] #2288415
04/15/17 09:01 PM
04/15/17 09:01 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Low hanging fruit: battery ground wires or battery post corroded. It is tough to catch an intermittent.
Craig
Re: Ram 1500 voltage problem [Re: LowDeck451] #2288844
04/16/17 02:34 PM
04/16/17 02:34 PM
California USA
California USA
denfireguy - Yeah, checked those things, gotta love intermittents! I'll keep diggin' though. Thanks for the response.
Re: Ram 1500 voltage problem [Re: LowDeck451] #2292958
04/23/17 10:55 PM
04/23/17 10:55 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you finally figure it is your ecm---you have a choice of buying a new unit or making the alternator a 1 wire with a trans-po conversion $35-----guys doing cummins conversions to older vehicles use these all the time---my son orders them 3 at a time when the price is right just to be sure to have them on hand when needed-----one time he ask to grab the one off my 69 gmc/cummins to get a customer on the road the same day-----if you want to see what it is--- just keyword cummins alternator regulator on ebay---they show up on amazon as well---it is the little silver box with 4 wires that fits inside the alternator case.....
Re: Ram 1500 voltage problem [Re: savoy64] #2293633
04/25/17 01:59 AM
04/25/17 01:59 AM
California USA
California USA
Thanks for the info. Since I first posted, I found a couple videos on bypassing the computer (ECM?) with an external voltage regulator (maybe this is along the lines of your suggestion?). Also, I hooked up my multi-meter to the battery terminals and drove the truck to see if when the problem happens, would my meter also show a high voltage reading, it didn't. Stayed in the same 14v range (tried this same setup with the battery cables disconnected from battery, same result). Does this mean the battery isn't being overcharged, and that it's some other problem? BTW, this problem only happens when I'm at highway RPM, above 1500. Thanks again.
