245-60-15s rubbing on front fenders, Cuda #2285389
04/10/17 06:10 PM
04/10/17 06:10 PM
Finally a HUSKER again
Moparnut426 Offline OP
I read everywhere that the 245-60s fit best, but they definitely rub. I was going to go to a 235-60. What are you guys running
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285397
04/10/17 06:19 PM
04/10/17 06:19 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What year of Cuda? What wheel width and back spacing?
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285423
04/10/17 07:35 PM
04/10/17 07:35 PM
73,
Stock back space, running a 15x7 weld pro star.
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285424
04/10/17 07:36 PM
04/10/17 07:36 PM
IIRC s actually 1/2" farther In than stock
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285452
04/10/17 08:24 PM
04/10/17 08:24 PM
WA
tman Online content
tman  Online Content
WA
I have that size tire on my 70 cuda on stock 15x7 Rallye wheels. No rubbing for me.
Re: 245-60-15s rubbing on front fenders, Cuda [Re: tman] #2285624
04/11/17 12:48 AM
04/11/17 12:48 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Same here, 245/60/15 and I've run 255/60/15 on 15x7 ralleys up fromy with no rub, it depends on the tire, some have a more rounded sidewall profile, some more square in profile, plus each mfg has slightly different widths for the same aspect sized tire, ride height also plays into it
Re: 245-60-15s rubbing on front fenders, Cuda [Re: DAYCLONA] #2285731
04/11/17 09:44 AM
04/11/17 09:44 AM
moparx Offline
moparx  Offline
amen to that. i have seen almost an inch difference in all dimensions from one manufacture to another while having the same size on the sidewalls. this includes all sizes and all profiles. i have been well aware of this for over 45 years. i was friends with a couple of re-cappers back in the day this was an acceptable, and often the only affordable option, to new tires. they would constantly gripe about how the tires would fit in the molds after they were ground for capping. those guys had a type of measuring device that would dictate how a tire would fit, and what sizes would go in each mold. as long as the wheel size was the same [13 to 16], and the measuring tool told what mold to use, that dictated what went into the specific mold. that was when bias tires were the only game in town. and those guys really had a fit when radials became the norm !
beer
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285746
04/11/17 10:29 AM
04/11/17 10:29 AM
looks like im going to be runnin 235/60-15s
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285768
04/11/17 11:42 AM
04/11/17 11:42 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You have to read all the mfg's data on their tire profile specs, and compare what you have currently to make a sound judgement before buying....you'll find that 235 may/may not be available depending on mfg's choice...and a 225 is just too small, with a little research you can find a 245 or 255 that will fit
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285786
04/11/17 12:22 PM
04/11/17 12:22 PM
the 235 is only about 1/2" smaller and a lil narrower so Ill do that. I not going to run a mis matched set if tires. Its ot BFgs all around now and Ill just use the 245s on my super bee.
Re: 245-60-15s rubbing on front fenders, Cuda [Re: Moparnut426] #2285827
04/11/17 02:09 PM
04/11/17 02:09 PM
pa.
dan9 Offline
dan9  Offline
pa.
I had the same problem with that size BFG's on my 70 Challenger. I got rid of the rubbing by tightening up the torsion bars (they had been removed and not adjusted properly).
