Re: Can a 4" stroke SB crank be turned to?
[Re: rt66jim]
#2285406
04/10/17 06:49 PM
04/10/17 06:49 PM
Posts: 4,457 Washington
madscientist
Washington
You'll get maybe .125 if you can take it that far.
[Re: justinp61]
#2285432
04/10/17 07:47 PM
04/10/17 07:47 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
4.25" cranks are readily available. I know but I have a set of Pankle rods with the smaller journal. I would like to use by just turning the crank I have.
[Re: rt66jim]
#2285435
04/10/17 07:52 PM
04/10/17 07:52 PM
Posts: 52,972 Romeo MI
MR_P_BODY
4.25" cranks are readily available. I know but I have a set of Pankle rods with the smaller journal. I would like to use by just turning the crank I have. You can.. just talk with your crank grinder for the clearance needed.. smaller dia will use less
[Re: MR_P_BODY]
#2285447
04/10/17 08:11 PM
04/10/17 08:11 PM
Posts: 1,784 PA
W5DART66
PA
2.125"? Or 2.100"? So 2.125" down to 1.850" = .275" you can not get it all but .250" should clean up back to round. So your stroke gain would be .500". 4.500" stroke but 1.85 on 4" crank will have no Journal overlap. Anything you offset will be 2 times the stroke gain. So .050" offset will give you .100" gain in stroke.
[Re: MR_P_BODY]
#2285449
04/10/17 08:21 PM
04/10/17 08:21 PM
dogdays
Those NASCAR rods are the siren luring you onto the rocks. The Honda journal, though, is 1.889" The Mitsubishi journal is 1.850"
Hughes' stroker was such an animal, a few years ago, except it used the Honda journal. 4.180 stroke.
R.
[Re: Blucuda413]
#2285457
04/10/17 08:29 PM
04/10/17 08:29 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Man, I wish mine would have worked like that. When I did my crank from a 2.125 to 2.00 I only gained .125 and only ended up with a 3.91 stroke What did I do wrong?? Did nothing wrong! Lots of WRONG info in this thread. Change in journal size is the max you can gain by offset grinding! 2.125-1.850=.275 MAX added stroke theoretically .250 is realistic
[Re: GTS340]
#2285530
04/10/17 10:04 PM
04/10/17 10:04 PM
Posts: 1,784 PA
W5DART66
PA
Man, I wish mine would have worked like that. When I did my crank from a 2.125 to 2.00 I only gained .125 and only ended up with a 3.91 stroke What did I do wrong?? Did nothing wrong! Lots of WRONG info in this thread. Change in journal size is the max you can gain by offset grinding! 2.125-1.850=.275 MAX added stroke theoretically .250 is realistic Dude you should check your facts.... Will not argue with you I offset cranks all the time. You double What you offset period
[Re: W5DART66]
#2285568
04/10/17 11:02 PM
04/10/17 11:02 PM
Posts: 1,784 PA
W5DART66
PA
[Re: Blucuda413]
#2285569
04/10/17 11:04 PM
04/10/17 11:04 PM
Posts: 1,784 PA
W5DART66
PA
Yes I know, I was just trying to throw a little levity into the discussion. The offset = stroke increase was the way it worked when I took plane geometry 70 years ago. It changes the center line of the Journal in relation to the mains. And it turns in a circle so it doubles what ever is offset ground.
[Re: rt66jim]
#2285579
04/10/17 11:32 PM
04/10/17 11:32 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
You sure about that Brett!! You only just offset the crank in the 981hp small block you built.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: GTS340]
#2285643
04/11/17 01:28 AM
04/11/17 01:28 AM
1967dartgt
Hilltown Pa
Man, I wish mine would have worked like that. When I did my crank from a 2.125 to 2.00 I only gained .125 and only ended up with a 3.91 stroke What did I do wrong?? Did nothing wrong! Lots of WRONG info in this thread. Change in journal size is the max you can gain by offset grinding! 2.125-1.850=.275 MAX added stroke theoretically .250 is realistic Man lots of bad info in this thread. You have a engine builder correct you and you tell him he is wrong, wow. Wonder why so many people stopped posting in here.
[Re: 1967dartgt]
#2285682
04/11/17 03:47 AM
04/11/17 03:47 AM
RapidRobert
visualize a 1" circle inside a 2" circle. there is 1/2" of space vertical above it and 1/2 of space underneath it. If you moved the circle to the bottom it would move 1/2" (minus a bit for cleanup to get it back to concentric), this is the "throw" increase (1/2"). doubling that would be the stroke increase (1") cuz it would push the piston 1/2" higher at TDC and 1/2" lower at BDC then where it was before. EDIT for a slight stroke increase with all Mopar stuff to finalize quench for instance, CNC motorsports has 50 under SB rod bearings & eBay has some 40 under
[Re: rt66jim]
#2285695
04/11/17 05:15 AM
04/11/17 05:15 AM
Posts: 43,240 Bend,OR USA
Cab_Burge
It depends on the crankshaft and its oil passages, I have several older forged top fuel cranks with Mopar rod journal sizes, one KB that is 4.500 stroke and according to the crankshaft shop I sent it to it can't be offset ground and destroked due to the oil passages or something else I can't remember now I sent them a another older forged Bryant 4.250 stroke top fuel crank with stock Mopar BB rod journal sizes with one spun rod bearing journal and they offset ground it down to 2.200 and 4.375 stroke with no issues Check twice before deciding
[Re: rt66jim]
#2285706
04/11/17 08:15 AM
04/11/17 08:15 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Brett, no doubt you can build a great engine, and are an absolute master with cylinder heads, but you can't math.
